DIY: Ichiba v2 20MM wheel spacer's
07' CBP Type-s
Whats up everyone!. Put together a DIY for installing Ichiba v2 20mm wheel spacers. ( Be aware that there are risks with using wheel spacers) but installed properly and doing about 2 re-torque's after 30-50 miles they should be fine. I am not a mechanic just a guy who did his research as should you and likes to work on cars, so take this info as you will.
Lets get started...
Working on a 2007 Acura TL Type-S (No drop...yet
Wheel spec's 19x8.5 235/35 tires
Tools:
A Jack
Jack Stand('s)
Wheel chocks
A tire iron (a "T" or the OEM one is fine)
1/2" Torque wrench
sand paper
Anti-seize (optional)
rubber mallet or hammer
What we are installing: Ichiba V2 20mm wheel Spacers
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0611-53109.jpg)
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0612-53108.jpg)
1. First make sure the E-brake is on and wheel chocks are in place. Jack up the car and put your jack stand securely under the car on your OEM jack stand points (refer to car manual if needed).
![](http://C:%5CUsers%5Ckjtkreations%5CDesktop%5CNew%20Folder%20%282%29)
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0607-53105.jpg)
![](http://https://acurazine.com/forums/album.php?albumid=11595&pictureid=53105)
Next remove wheel
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0605-53106.jpg)
2. Clean off any flaking rust so you have a nice surface for the spacer. I used a little of this
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0608-53110.jpg)
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0609-53107.jpg)
Spray a little on and wipe off with paper towel.
I also sanded (220 grit) just a to remove some of the rust.
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0610-53111.jpg)
3. Next put on the wheel hub ring supplied by Ichiba (They must must must be hub-centric to your OEM hub's)
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0613-53112.jpg)
Push on the hub ring, you will need a rubber mallet or a hammer. Just tap on the ring carefully if your using a metal hammer. The fitment should be nice and snug up against your OEM hub.
4. Place your wheel spacer on (Anti-seize is optional here) I used just a TINY bit on the OEM studs.
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0614-53113.jpg)
5. Place the bolt's one to your OEM stud's and Torque to 80 Ft/lb. These are the spec's that Ichiba recommends for these spacers.
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0615-53114.jpg)
6. Torque to 80 ft/lb and do a re-torque at 35 miles, do this at least two times.
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0617-53116.jpg)
The bolt for the spacer should not be flush with the face of the spacer. This can cause a gap that you do not want.
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0616-53115.jpg)
Note: If you do get a pair of spacers and the spacer bolt does come flush with the face of the spacer. Make sure that the wheel you are putting on has big enough holes on the back to accommodate the bolt face. You do not want a gap.
Before mounting wheels
I also sanded the back of my aftermarket wheels (NOTICE the black hub centric ring in the bore. If your Aftermarket wheels have a bigger bore size then (OEM 64.1mm) you want to get hub centric ring's so you don't have vibrations. Got these on ebay for $9 for 4. My rings are 73mm to a 64.1mm
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0618-53117.jpg)
If you are putting on aftermarket wheel make sure you have big enough and deep enough holes in the back for your OEM studs to fit in.
After that just mount your wheels back on and don't forget to re-torque. Have fun and be safe !
Crap picture and she's dirty![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
![](https://acurazine.com/forums/members/nomercy_tl-311500-albums-spacer-diy-11595-picture-img-0619-53118.jpg)
Lets get started...
Tools:
A Jack
Jack Stand('s)
Wheel chocks
1/2" Torque wrench
sand paper
Next remove wheel
The following 4 users liked this post by NoMercy_TL:
Nicely done! 3G Garage this bish.
BANNED
^nope it's the same front and back. easy job
BreezyTL (09-28-2013)
Received 6,470 Likes
Nice work, NM.
Anxious for updated pics.
07' CBP Type-s
Yes, they do rub in the rear. Come summer I hope to roll the fenders and lower the car with coilovers and give it some negative camber.The wheels are 8x5 all around with a 40 offset. I don't need the spacers in the rear, but with out them it looks off from the front were the spacers are needed.
No issues with rubbing
BxTrini_TL (11-01-2013)
Ok so let me make this clear.. I have stock UA6 and also will soon be dropped with tein s-tech. Whats the best safest recommeded spacers to use without having to run into any issues? I been seeing 15mm front and 20mm back. Can I safetly do 20mm front 25mm back? Thanks!
![Yes](https://acurazine.com/forums/images/smilies/yes.gif)
BxTrini_TL (11-02-2013)
Whats up with the "off road use only" designation?
Question guys, im lowered on rpf1s 17x9 +45 looking to put 20mm spacers up front and 25mm in the back and slamming the car to get some nice fitment, do you guys think i would rub into any rubbing issues in the front with the 20mm or should i got 15mm?
AMTL (03-29-2016)
DarkTower19 (03-30-2016)
jmoney2001
09-11-2015 12:07 PM
