Different measurements on ride height
Old 09-16-2013 | 09:50 PM
o666los's Avatar
So I have the f&f type II and I recently went lower and made the measurements the same... fronts were 3 7/8 and I forget the rear.... but when I did the fronts thats what they measured (lower bracket) and the driver side was lower even though they measured the same... did the rears and same problem so pretty much I had to play with it and I have all different measurements.... is this normal????
Old 09-17-2013 | 09:26 AM
CLtotheTL32's Avatar
Are you measuring the distance from the ground to the fender or are you measuring how much you've adjusted on the coilover? Do you drive your car around for a bit before measuring?
Old 09-18-2013 | 09:18 PM
o666los's Avatar
Im measuring the lower bracket height... not the preload
and when I adjust it lets say 1/2 inch it moves slightly and I dont drive it but is that normal???
Old 09-18-2013 | 09:20 PM
Slpr04UA6's Avatar
-------Tim-------
^drive it around the block a couple times, then measure. I am not 100% it will solve you problem, but the measurements will change.
Old 09-18-2013 | 10:04 PM
KidJdm's Avatar
I think its normal. Because imagine the driver side has steering wheels and more weight on the driver side so it could be that. For me I just keep adjusting one side until they were both even.
emailnatec
29
09-28-2018 05:27 PM
07-16-2017 08:33 AM
Froid
09-27-2015 07:16 PM
flybyglass
09-24-2015 02:12 PM
4drviper
09-23-2015 08:42 PM
Quick Reply: Different measurements on ride height
