Dealer Replacing EL42s With RE030s
Is that what you want ? A Summer or an All-Season tire
The Re030's are summer only tires and have a treadwear rating of 140, in all likelyhood they will only last you one summer.
Pilot AS and RE030 are completely different tires, if you want an all-season tire that has a wear rating of 400 then go with the Michelins
Originally Posted by bluenoser
Is this a good thing, or do I drive straight to a Michelin dealer for Pilot AS.
i'm using the RE030's now and they're great. then again i live in california where its 90 degrees today :toothless
Originally Posted by roadman
Was this the $200 performance tires option w/6MT ?
yup. i looked at the stock turanzas and said fukit, i'll pony up the extra 200 bones for some real tires.
Audi replaced REo40s on the TTs for
sidewall bubbling. I put Kumhos on and sent Audi the bill. they paid me over $600 and then I ebayed my Blowtenzas! :thefinger
The Michelin dealer offered me $40 Cdn. for the tires - with three miles on them, that makes the Pilot AS only $1,250 Cdn. to purchase. That's out of the question. My dealer said the RE030's are the replacement for defective EL42's.
I haven't driven far enough to make a performance opinion, but they are one noisy, singing tire. They feel like I'm driving on cordoroy roads.
Unfortunatly all four rims were scraped all around the outside during the installation - the dealer said they would take care of it. Should I accept a paint job or hold out for new rims.
Is there an issue with temperature with the RE030s?
The rerurn trip wore out another set of rears.
I had the alignment checked and it was only at the limits in one measurement, but the rubber was literally ripped off the tires.
The car was carrying four adults, with luggage - but well within the load capacity of the car.
I suspect the rear geometry is drastically off when carrying loads.
Originally Posted by rets
bluenoser,
You have winter tires, right? Had your winter tires wore out as your EL42s? What the winter tires are you using?
The RL rims have the same onset and are 6.5"wide, which means the offset is 1.5" less than the 04 rims.
Harvest day sucks....
Moderator Alumnus
I prefer to have the rear end suspension and alignment checked prior to having the brand new tires. If it's not the EL42s' fault, you probably will wear out another new tires very soon.
asahrts
09-04-2015 05:55 PM
