Dang TPMS on the fritz?
over the last 2 weeks or so I am repeatedly getting the TPMS low tire pressure warning and dinging sound. When this happens the tires are always within 1-2 lbs of each other. Currently three read 29 and one reads 28, but I'm still getting the warning. I know that they need to be a little higher (like 33 or so), but I just haven't had the chance lately to put air in them. However, I was under the impression that the warning wasnt based on the actual pressure but rather the difference in pressure with the other tires.
Anyway, I'll increase them all up to 32-33 this evening if I get a chance and hope it stops, but if it doesnt does anyone have any ideas? I also suspect that the colder weather we're having now could be impacting pressure readings slightly, but still this is getting anoying.
I just installed a set of snows on my 08 TL they are 215/55/16 michelin x-ice mounted on genuine acura steel rims. I also bought a set of TPMS sensors from Acura and installed them now they read 58psi at all four positions. Do they have to be programmed or will they eventually learn the actual tire pressure wich is presently 32-34psi. Any help would be appreciated Thanks
neuronbob
23
07-16-2019 10:48 AM
