Damper Fork Bolt
Damper Fork Bolt
Any tricks to getting the lower Damper Fork bolt out? I've already broken an extension and ratchet trying to break it free and hammering doesn't appear to be doing anything.
Already have the nut off but I can't break the bolt free of the bushing.
Turd Polisher
Once I got the nut off, I put a flat head screwdriver through the hole and hit it very gently.
If its that bad, you def need to soak with good penetration lube for awhile. You can only do so much without damaging that bushing. Might have to replace it depending on how it goes.
I use the pen lube, and try to rotate the bolt and tap with a small sledge to help work the pen lube in, soak in for awhile. Then use a small sledge and punch to work it out, w/ a few accurate and forceful hits. I've honestly never had this problem on a 3rd gen though, but plenty on other Honda's.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
