D.I.Y. Relaxing your suspension bushings
#43
oops is that your face?
haha no prob, I wasnt very clear but thanks again for the DIY it was helpful. there was one bushing in the rear on either side that I did neglect due to clearance, I hit one end but the other that was closest to the center of the car I didn't do but I guess some is better than none lol.
#44
This is an interesting read. I have not adjusted the height of my wife's TL, but as I lifted my 4Runner I don't think I re-torqued everything with it weighted down at the ride height. I think when I do my oil change & rotation of tires, that I will add this to my to do list for my checkout of my suspension. As I had already planned to double check all the torques on everything.
#45
What if I accidentally removed the toe adjustment bolt....
I mean I put it back in... (all with the car in the air)
I still need to untighten and retighten the bolts then get an alignment.
#46
I'm surprised you were able to remove it. When I installed my 2 arm camber kit, I had to cut off the sonbish and buy new ones. Others had the same issue with rust.
#47
You will need an alignment for sure. I assume you never got it aligned after you lowered it then ether?
#48
I lowered it last week. Waited a week for everything to settle then I forgot about this.. I can go a few weeks without an alignment it will be fine.
This just involves loosening the bolts and NOT taking them all the way out right...
#49
I have an electric impact which made everything very easy
#53
NO this will NOT fix your crooked springs. that seems like a dangerous situation, maybe the springs arent seated right and can pop loose in the right condition. get that fixed asap! what brand springs are those? maybe its a defect too
#54
I just got off the phone with the manufacture and they asked me to email them pictures. So I'm waiting to hear back from them. I really have a hard time believing that the springs are defective to be honest.
I should add that at the time of install, I also had the Ingalls rear camber + toe kit installed. Could an incorrect installation of these parts affect the springs in this way? Here are some pictures of the perches and top mounts.
The following 2 users liked this post by Roger555:
rockstar143 (08-05-2013),
Wacker (08-05-2013)
#56
Very interesting. Good read
Wacker (08-05-2013)
Wacker (08-06-2013)
#62
So, what exactly am i lowering back down on? I understand, jack the car up from front or rear middle, then lower onto jack stands/blocks onto..? Then the car will be at ride height with no tires on, correct? Lol, don't know why I'm having a hard time with this.
#63
That's exactly right...you want the car's suspension fully compressed as if NOT on a jack, BUT obviously you need that done with the wheel not there so you can access the bolts.
You can do 2nd jack under the hub with a piece of wood to prevent it rolling and metal on metal...or you can stack something strong, like a jack stand or wood pile under the hub/rotor face and lower the car until the jack isn't the one holding the weight up.
Personally, I prefer 2nd jack method, that way the jack is still there...you jack up 2nd one until you see the weight of car transfer to the second jack under the hub, loosen all rotating bushings, let them pop, re tighten and you're done.
Luketic (05-01-2014)
#64
iWhine
Having read through this some time ago, I just wanted to come back in here and thank you guys for this info as It wasn't until recently that I decided to finally do this. it helped smooth out the ride quality of my setup from what initially felt like excess rebound over dips and bumps. Passengers have also referenced the improved ride quality.
Anybody who isn't happy with the ride quality of their setup, give this a try if you haven't already. I was surprised how much it helped.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
