Cross drilled and slotted rotors help
#42
CARBON FIBER WDP TL
Right now the RL calipers are going for 300 used on ebay, right now im waiting to see if a connection at my local parts acura dealer can get them for a better price for me. The rotor will have to be 13" from stoptech and dont believe the stock TL will work with the RL calipers. But will check, thanks. My other connects is a distubutor for stoptech so I cam get a hood price.
#43
What's up everyone.
I have a 2007 TL-S, 57k miles - stock everything.
Back in August 2011 I knew i was needing new brakes front/back so I proceeded and ordered stock Honda OEM brake pads on ebay from an Acura dealer in NY that were at a good price compared to local dealers and buying pads from autozone, pep boys, etc.... As I went in for an oil change on 1/12/13, turns out my rear brakes are at a "9/10" scale and my fronts are at a "3/10". I found it hard to believe since I only use my car weeknights and weekends (use public trans to/from work) so basically my car is hardly used and since Aug 2011 have probably only put 8k miles on.
I was told that my rotors were fine when I replaced the pads and figured the next pad change I would be upgrading my rotors to drilled/slotted. Now, I'm waiting to take my car to my mechanic so he can check my brake pads since I don't believe dealer. I've been told by one dealer "you need new brakes, want us to take care of that for you" and on the next oil change at another location "your brakes are good, you'll need them soon though". With all that being said and reading through this thread, I am now torn. Idk which rotors to order and what pads to use.
Do I just replace my front rotors and pads and let the rear wear out? or should i swap both front/back rotors and replace front pads? so confused. lol
Also, are there any mods that need to be made when replacing the original rear rotors?
Please advise. Thanks everyone
#44
What's up everyone.
when i went in to change the fronts, the mechanic said i should change the rotor at the same time instead of machining it.
no mods needed to change the rotors. go with stoptech or brakemotive rotors. for pads i went with stoptech and i'm very happy about the performance and minimal dust.
revel_one (01-14-2013)
#45
i have 59k on my type s and I have only replaced the front pads once...I have not replaced the rear pads yet, but the front typically will wear faster. i would just replace the front and let the rear pads stay on there.
I just find it weird that my mechanic told me the rotors were fine but maybe on the next brake job they would need to be replaced and he isn't fond of machining the rotors also. As mentioned both front/back brakes were replaced but to compare 90/100 on rear and 30/100 on front in 16month (8k miles - mostly city driving) ? kind of crazy to me.
I'm hoping
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
thanks again everyone
#46
did you use stoptechs rotors as well? I typically see both stoptech and brakemotive names thrown out in all the brake/rotor discussions and the same argument/preference that some people have about one being better than the other.
I'm hoping
that my mechanic has time to check them out this weekend or tell me that the dealer is simply pulling my leg to get some $$$ ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I'm hoping
city driving is more harsh on the brakes and it depends on how you drive with relation to wear. keep us updated!
#47
i was expecting them to machine my rotors so i didn't pre-buy rotors, so they just used whatever they had on the shelf, which sucks cuz the hubs rust and look horrible and i wanted the slotted rotors. i don't think you can go wrong with stoptech or brakemotive.
Did you ever swap your rotors after Sockr1?
#51
TL-S
I had the Brakemotive brakes on my 5at and never had an issue.
I just got them for my Type-S because I got a great deal on them.
I still haven't heard of anyone having any major issues. Only complaint I have is that they are noisy, but that comes with all drilled rotors as far as I know.
#53
i just ordered front stop tech/power slot/centric slotted rotors (unbeknownst to me, its all 1 company) and stoptech street pads. $297 shipped from autoanything on ebay (theyre in socal).
had to pay in-state sales tax, but it was cheaper than paying for shipping due to weight.
#54
Former Sponsor
#56
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
09-25-2015 06:14 PM
