Cost of replacing complete front suspension passenger side only
I was racing a buddy of mine down here in South Florida a few night ago on a small, poorly lit unfortunately, 2 lane back road. I was going around 110 when I nailed a huge pothole that completely bent the rim and knocked the wheel so far off alignment that even the spare rubs the back of the wheel well. Took it to a body shop, they said I need to completely replace the front passenger side suspension, just curious what that should cost me. I've been burned by shops before and just trying to prevent it from happening again. He is going to call me in the morning with the quote, just wanted to get y'all's opinion as well.
Glad it was a pothole and not a person.
I'd be concerned that the sub-frame might be compromised, but go to a local yard and if you have the OEM suspension, purchase the complete right side assembly. LCA, UCA, Fork, Shock assembly, and check the stabilizer and end link, possibly @ $200.
If damage to the sub-frame can't be seen, replace the entire suspension and then you'll know. Either put it on an alignment rack, or check the measurement each side center of wheel front to rear and compare. Should be the same.
If you're speaking of new parts with list prices, probably @ $1500/$2000 installed without wheel/tire, but if sub-frame is damaged it might be a problem as the part is no longer available for the TLS.
Time to use collision insurance, if you have the coverage on the car.
