Confuse about tire size?
Please help me, I'm confuse about choosing a tire size. I'm planning to get the Azul Speed 6(http://wheelsnext.com/default.?action=dspWheel&MODEL=SPEED%2D6&color=BLA CK%20(GLOSS%20FINISH), they are 18 in. but I was confuse if I should get it with the Dunlop tire size 235-40-18 or with the tire size 235-45-18. By the way which tire size will be safer for the rims so that I wont damgae the rims? If anyone have pics of their tire size please post as much as possible so that I can get an idea of what tire size I should get. Thank you so much!!
AZ Community Team
Received 7,770 Likes
I suggest you use this (or a similar) tire size calculator. This one will throw an error if the calculated diameter is off by more than 3% from stock (235/45/17).
It'll also show sidewall height, recomended rim size, speedo error, etc.
http://www.1010tires.com/TireSizeCalculator.asp
Assuming that your wheels are 18x8 then 245/40 18 is the right size. If you want greater rim protection then you should get 255/40 18s, should rolling size should still be close enough. 235/40 18 wont give you much rim protection at all.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
