Concave TE37 fitment?
I may be inheriting my wife's 08 6spd TL-S. I am a huge fan of the TE37 and especially when it's concave. Would it be too difficult to fit a 18x9.5+22 at all four corners? If so, what other offsets in either 9 or 9.5" widths will have a concave face? I believe 18x9+35 but I'm not sure.
It's important that it fits in front because I'm not a fan of staggering a FWD car. Thanks in advance!
HE>i
18x9.5 +22 with 215/40 tire. Lower car, roll fenders, and around -2/-2.5 degrees camber.
It will work, but we need more info on what future goals you have. Are looking for stance, being slammed, or just simply adding wheels and calling it a day?
TE's are a good chioce for the TL
Well maybe ill have to nix the +22s then because I wanted a meaty, track-oriented setup. My goals for the car are intake/J pipe/exhaust, coilovers and a carbon hood, plus other various things here and there like repaint the front bumper, convert all the interior bulbs to LED and get some audio equipment. I also would entertain more ways to make more power, but not get too crazy as this is and will remain a daily driver (we may just switch so she can trade my car in for something else).
But in regards to wheel/tire setup, I just want four same-offset, concave TE37s in bronze (the car is NBP) and I can kick out the rears with spacers. As stated above, I want the widest tire I can fit given my rigid opinion on concavity. I plan on lowering the car so there is a 1/4" gap, any amount of camber is fine to not poke the tires
I believe it concaves starting at +22 offset. Any higher and it will be flat face if I am right. The OP doesn't want to stretch tires. My guess is it will poke and rub it you throw on 265's, given the offset and width.
jaycao (07-07-2013)
OK... So I've been looking at Varrstoen ES2.2.1 in 18" diameter. I DO NOT want to get too crazy with the fender modification. Will an 18x9.5 +30 wheel clear the Brembos AND fit in the fenders with only minor rolling?
Received 3,824 Likes
^ Depends on what tire you run also.
The specs on my wheels (not TE) are 18x9 +30 on 235 tires and I'm lowered about 2" or so, no fender modifications at all and I DO NOT rub.
Hey buddy I'm running Varrstoen ES2 19x9.5+12 offest in the front and 19x10.5+12 offset on the rear. I had my fender roll and my tires were 215/35/19 in front and 235/35/19 in the rear, I cut the top of my fender line in the front to have more clear turn sharp turn. All I have an issue is with my rear rubbing on turns and dips but I just need to pull my rear fender I think it will be good. But since your not going aggressive as me you probably need just a roll and depends how low u want to go.
Well, I have already found that rims that size are perfect for what I want fitment-wise, but these Varrstoens are only in 18x8.5" or 18x9.5". One member a few years ago had 18x9" +15, but that is too aggressive.
My choices in 8.5" are: +25 or +35 and
my choices in 9.5" are: +22 or +30.
I am worried in either 8.5" width that I would have clearance issues with the Brembos. With the 18x9.5 +22s I'd have to do too much fender work, so that's out.
I'd like to see if either the 18x8.5 +25 or 18.9.5 +30 fit - so please let me know.
It's the offset you'd be worried about, not width for clearing Brembos. I don't have Brembos so idk what is the least you could get away with, someone else would have to confirm.
Yea... I know it's offset, I'm just not sure how a skinnier wheel fits with only a +5 difference in offset - it could be more/less concave, etc. and that would have an effect on clearance.
Try this out
https://acurazine.com/forums/tire_rim_calculator.php
I see that either width/offset combination works within my constraints... The 8.5 +25 probably being the better choice... It all boils down to clearing the Brembo if someone could chime in.
+25 should clear, that's 20mm farther out than stock.
Like I said, at 18x9 +30, I didn't have to roll fenders so at 8.5 +25 you'll be fine. Only thing now is the caliper clearance.
Someone needs to jump in here and confirm!
adreano17
09-29-2015 08:48 AM
nuldabz
09-03-2015 05:49 PM
