Comptech Springs - Sagging Rear?
Hi guys,
I have the silver Comptech lowering springs on my 05.
Can anyone else who has the same springs chime in and let me know if they are susceptible to spring sag in the rear? It's been like this for a few months now and I'm debating if I should just get a new set of rear struts or if it's due to age of the rear springs over time. If it's the springs, then I am just going to spring for coilovers.
how long ago you install the spring?
I bought the car Spring 2016, the previous owner installed the Comptechs. Not sure of install date though. They are installed in conjunction with OEM struts.
No subwoofers and trunk is virtually empty, minus some basic hand tools e.i. wrenches, screwdrivers, etc...
I have noticed that since winter has started, when going over bumps, I'll hear a clunk noise from the rear. After searching through a few threads, it seems the sound could be rear end links need replacing, but I'm not sure how that could affect ride height. I've also read in the 2G forums that Silver Comptechs had issues on CL/TL, mainly rusting and snapping. Not sure if those issues carried over to the 3G versions but I took a look lastnight and have zero rust on the springs and struts.
Dang...wonder if mine is a part of that bad batch. The ones I have are grey/silver in color. Unfortunately, I won't have a chance to jack car up to look for part numbers due to snow starting here in New England.
