Comptech RSB is on!
Comptech RSB is on!
I got it about a week ago, finally got my lazy butt under the car, took some extra time to make sure it was exactly lined up side to side, and torqued the bolts to 40 ft lbs, wasn't sure on the spec, and 25 seemed too loose. Car is noticably tighter around turns, and I can come up to a turn tap the brakes and toss the car, and it hooks w/o plowing like it used to. I have a 6MT to go on the front as well, but it won't be on till tomorrow as it rained today.
Last night as I was finishing the install, it hailed like a bitch. Have about 4K worth of damage to my brand new car, I don't even have real plates yet.
Aw well, I wanted a RL anyways, just gives me a reason to save up.
Originally Posted by jhan1102
Is the A-Spec sway bar same as the 6MT sway bar?
Originally Posted by MugenR
uh.... if you have a 5AT i think you still use the 17mm bar regardless of ASPEC or not
Again, the A-Spec TL does not include a sway bar. What you have on your car at time of purchase is what you will have when the A-Spec is installed. The only change made to the sway bar is one that you make yourself.
Like I said before, I have the comptech sway bar and I just wanted to know if there was any difference.
You answered it few posts up.
I get your point homeboy.
When I was working on my A-Spec suspension I noticed that the front sway bar was going to be a BITCH to get in. Let us know how that goes.
Took the front driver wheel off, after I jacked up the car
Leaned into the wheel well to find out what up, see sway bar, see it is INVERSELY FUC-EN MOUNTED under the damn motor craddle!
Proceed to put wheel back on and call Acura dealer...
I am either going to try to return the bar and bushings, or, ask for some way to get it installed... This is NOT a do it your self job. The rear was CAKE, the front looks like dropping the motor down on a lift...
The 6MT bar is noticably larger, and it was about $90 bucks plus the bushings which were 15, which is about the same as the CT RSB... I will sell it to you if you want to play with your car more, I just don't fell like dropping the engine cradle in my driveway.
Careful there, cowbow... you'll wear out your outside edges of your tires a lot faster if you do that!
But I can't stop.
I know... this is one of the things I am worried about. HAHAHAHA
But I can't stop.
But I can't stop.
Jul 16, 2017 07:33 AM
BoricuaTL
Apr 8, 2016 01:08 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
