Comptech Rear Sway Bar Installed
#41
Originally Posted by captain
Originally Posted by goBig
Ooops, it's actually I=(PI*D^4)/64, I forgot the 64.
Yah what he said... I obviously only took Intro to Physics. But GoBig seems to know what he is talking about... the point is that the Comptech should be noticeable stiffer than the 6mt sway bar.
#43
One on the right for me
Originally Posted by GrayFox
Hi,
I just ordered a comptech rsb, does anyone know the appropriate
torque to be used when installing the rascal?
Jerry
Jerry
also to go back to the aspec suspension talk, i was trying to decide between the tein coilovers or the aspec, and i think im going to opt for the aspec. i do all installs myself since im a mechanic, well it would make sense. for 600 bucks for a full set is damn good, while i havent driven a car with any other kind of aftermarket suspension i did notice a huge difference between stock and aspec, plus the acura warranty is nice.
#44
I bought and intalled the a-spec suspension also. Very easy and fully enjoying it. Glad to see someone else is expressing that a torque wrench isn't really necessary on this type of job. Your car isn't built with a torque wrench which you'll discover after working on it. Now if your building an engine, a torque wrench is definately needed. Both the sway bar and the a-spec suspension are diy jobs with basic tools.
#45
I don't want to get in over my head but would love to save a couple of hundred dollars.
TIA
#46
Originally Posted by ChuckDu
Is the a-spec suspension really a diy job for someone who is pretty handy? My intuition says yes (as you do) since the struts and springs come as a unit. So what are the roadblocks I'd have to look out for? Any tips?
TIA
TIA
#48
Hey,
I just had the A-Spec suspension $600.00 and the Comtech Say Bar installed and, yes I love the diffrence. I have a question...Is it normal to hear a noticeable, "twang," sound coming from the front towers upon turning hard during breaking or going up or down a sharp incline. This has happened three times now since my install. My buddy says it is settleing. I think it is BS. I think they did not tourqe it enough. They say you should not tourqe it too tight. I don't think anything broke, I just wonder if all these people saying you don't need a tourque wrench are incorrect and Acura's standards are serious reccomendations and should be followed?
BTW- The stock sway bar on the auto is so flimsy, I'd not be suprised to see it on a '93 Infiniti G20, my last car.
#49
T-Mobile -
As far as my experience has gone there has never been a "twang" sound ever. I would have noticed that since I am always listening to the car and would be concerned as much as you. Don't worry about the torque wrench issue. Check your endlink connections (front and back) and make sure they are secure. Your description of events points more towards that than the struts. Let us know.
#50
Originally Posted by cvajs
is it really only $600 for the a-spec shock/springs/installed ??
Tokico Illumina & Eibach 4044.140 $635
Tein Basic kit $730
Koni/Eibach kit $795
i would opt for aftermarket parts.
Tein Basic kit $730
do you have the part# for Tokico Illumina? i am looking for one, but after all the searches, i am still not sure if they will fit... i really need help here
#51
But anyway, I know the sway bar is to help the roll, but has anyone noticed a rougher ride in an auto?
#52
I have the same question. With the 22mm comptech swaybar, is there any ride comfort lost in this handling gain vs stock auto. Are bumbs sharper in the back or anything? Also do they make any creaking noises over time that can become annoyiing?
#54
Trucki!!
#55
Lt. Dangle
Just bought mine from Acura of Escondido . . .
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8076274671
8 left as of this post.
#56
My thoughts on the handling change
I installed the Comptech RSB Sunday and took it out for a spin. I must say it does really tighten up the rear a lot. It does not lean like it used to at all. When I flick the steering wheel, the car is much more responsive (but still not as good as my old 3 series). By the way, I have a 5AT.
The funny thing is now that the rear is tighter and I take turns harder, the front feel a little more swishey that the rear. It is almost like I need something to button down the front to match the tightness the rear has now. Anyone else feel this?
Regarding the roughness of the ride changing question earlier, it feels only slightly different. If you take stock roughness as a 6 out of 10, the rear swaybar makes it feel like a 6.2 which is barely any difference.
#60
bodyroll is eliminated? No it isn't.. it's just a little more nimble in turns.. I have an A-spec suspension, 18" Aspec rims, the CT RSB and YES! there IS still bodyroll...
You're just not driving into turns past 15 mph .. that's why you're not experiencing the bodyroll.
It's an improvement (the CT RSB) but it's not THAT much of one.
#61
I did not mean there was NO body roll but compared to stock, it feels like the body roll is reduced dramatically.
I know what no body roll feels like. I used to have an old RX-7 with a lot of money invested in the suspension (and motor). That car handled like crazy. I miss that car.
#65
Ride comfort
Just to expand a bit from an engineers standpoint, the reason Acura doesn't include the stiffer swaybar is that it does reduce the overall ride comfort a bit. They have a particular ride in mind & don't wish to change something that will cause the ride to be harsher. This is why the car is classified as a luxury-sport vehicle. If it was merely sport, they could sacrifice ride quality.
How is the ride affected? A sway bar affects how a car reacts side to side. Thus, for instance if you rolled over a speed bump where both rear wheels are affected at the same time, you would not feel the stiffer sway bar. However, if you hit a bump or dip with one side only, then the stiffer sway bar would be felt. The heavier bar would have less give & thus transmit more of that bump to the rest of the car.
It may not be the easiest thing to notice, as the affect may feel negligible to most, however in engineering a vehicles ride, every little bit adds up. To answer the next question-your high speed stability should be greater with the stiffer sway bar. If you've ever driven a big old Town Car with the plush suspension & then get hit with a strong crosswind, you'll quickly yearn for a stiffer ride.
As a funny & embarrassing side note, when I was a kid in high school, my first car was a Chevette. JC Whitney offered a heavier sway bar for the front & actually had a sway bar for the rear. I added both & the difference was amazing. Combining those with some fatter low profile tires & that little POS cornered like you wouldn't believe. I think it was that experience that moved me to appreciate improved handling over just improved horsepower. Thankfully I'm all grown up now & experiencing the wonders of the TL & BMW M series.
#66
Great post Swanny05TL - couldn't have explained it better myself .
A question related to this RSB - for those who did their own install how long did it take you to do? My dealer who is an authorized Comptech retailer / installer wants ~ $150 which is about 1.5 hours @ rack rate. I can't believe that with a lift AND air tools it could possbily take 1.5 hours. In prior cars I installed RSB's and it only took about 1.5 hours with jackstands and hand tools in my garage.
Am I waaaay off base here or what? TIA .
#67
I hae purchased my CT RSB and in the spirit of friendship i want to give my stock RSB to a close friend of mine that has a 05 accord 2 door, will this fit his car??
Ps. I will be posting vids of last weekends Monkey tachtics stunt show featuring me in my 06 TL ripping a baddass 400+foot burnout and a 900+hp 02' T/A, I need to get some time to edit it nicely so you all will be impressed, oh and i raced the T/A and beat him LOL thats not on the video he couldent grab any traction and i just gingerly pulled away and beat him
#69
Originally Posted by TurboSam
do you have the auto or 6 speed TL. i have a 6 speed, and i eager to know if the 2mm difference is really worht the 90 bux for the sway bar
#70
#71
Well.... finally got the Comptech RSB on the car. Had the dealer do it so they couldn't bitch at me re: warranty and extended warranty and got bent over a bit for it but it showed me what the dealer that sold me the car was really about - won't be goin back there again .
My initial impressions are qutie favourable . Nice and notable improvement in handling and very little difference in ride. Only time I notice a slight difference is when I run over something - like a pothole cover - with only one of the two rear wheels. A little more harsh but nothing too bad - worth the sacrifice given the improvment in handling. The difference wouldn't be noticable by anyone not looking for it ... but i was .
All in all a good bang for the buck mod IMHO .
#73
Unshunned
you guys with the RSB upgrade: Are you running stock tires or Z-rated/hi-perf. tires or what kinds?
I'm running on 245/45ZR- 17 Falken Azenis, and I LOVE how they tigten up the handling. I'm just wondering if this sway bar will be as noticeable as to someone with stock tires or non-z-rated styles of tire.....
#74
I'm running the stock Mich's for now. I believe you would still notice a difference even with those tires as the Comptech RSB will help manage load shift which should translate to improved handling for ya.
#75
I changed out the stock Michelin H4's for Pilot Sport A/S's of the same size before I put the Comptech RSB on. The tire change out was most noticible in wet conditions as the H4's didn't have very good wet traction, but the Pilot Sorts were a little more progressive in response and felt better even in the dry. The H4's always felt squirelly to me.
After I installed the RSB, the rear did tighten up a little from the 20mm stock RSB on the 6MT. Less body lean and a little shaper turn in, but very modest. The improvement was marginal, but the cost was low, so I think it was worth it. If you have a 5AT with a 17mm RSB, it a no brainer as it will really improve the turn in.
#76
#77
I'll add my $0.02 here (since I'm not sure where else I should put it, and another thread is a waste).
I added a CT rear bar to my '06 Auto this weekend. After driving around on a large variety of roads, these are my thoughts.
1. High speed lane changes are much more predictable. The back of the car doesn't feel as sloppy as it did before.
2. The roll in the front of the car is very pronounced now (again, this is in an automatic). The car really needs a larger front roll bar. I would even go as far as saying the car has an odd unbalanced feel to it with the factory bar up front and the CT bar in the back.
3. Harshness and ride comfort were not impacted dramatically. I went out of my way to drive on roads that can challenge a stiffer suspension, and I did perceive a difference, but it was rather small. On bumpy corners, the rear suspension can skitter over bumps, but it did that with the factory rear bar as well. It's hard to quantify the difference. Ride quality from the front seat wasn't much stiffer. Rear seat occupants might feel otherwise...but I never rode in the back seat before I swapped the bar, and I can't reach the pedals and wheel from the back seat. :-P
I took a look at the front bar to see what's involved, and as the posts here have insinuated, it's a mess. There are too many contortions to rotate and fish it out...you really have to get stuff out of the way. Seems like you need to remove the cat, lower the rear portion of the subframe (while supporting the engine), and then you should be able to extract the bar. I'm not sure whether there are implications with the trans too...I just got a headache looking at the way they routed the damn bar. Ideally I would like to get a used bar from a 6 sp, find some lift time, and take a closer look to see if the 6 sp bar will work, and evaluate what else will need to be done to drop the subframe.
#79
05 TL
I replaced the front bushings this weekend. With some Energy Suspension Bushings. I like it alot more.
I will admit that it sucked, but only took me (by myself) about 4 hours... Most of it was pondering what to do next.
Removing it sucked, putting the ES bushings in was alot easier.
k6biv
09-10-2015 06:37 PM
