Comptech Rear Sway Bar
After installing this, does anyone really feel the difference? ANy detailed comments would be appreicated. Does the rsb come in effect only on "hard turns"?
SEARCH IS YOUR FRIEND!!!!
yea there's a spiral-type of onramp that i take to go to seattle. i used to only be able to hit like 45 on it without fear of losing control or rolling. i can EASILY take that turn hittin 60-70. even on the freeway, when i downshift and gun it, i get SLIGHT body roll, but that's because i haven't lowered it yet. hopefully soon
You can definitely feel like there is a change. I don't really know how to explain but to say the car feels more like its on rails during hard turns at higher speeds- as if the car were more confidently going through.
Definitely worth the money. Also, no noises coming from it yet.
Originally Posted by TLTrance
When the Comptech RSB is purchased, does it come with everything you need to make sure that there's no thumping (bushings)?
From what I was told yesterday, you can use the hardware already on the car. But there are some harder bushings available. I order mine yesterday from Excelerate $120.00 shipped.
My Garage not
1 Post
yea, when u get the install kit u don't need to buy anything else to put it on the tl. it's an easy install, just read the instructions. it's a simple bolt off the stock and bolt on the new. u don't need jacks, probably a set of cheap rhino ramps is the fastest and easiest way to get the bar on. the only hard part about it is taking off 2 of the guerrilla tightened end link bolts.
yea, u'll definitely feel the difference and can't do better for like 100 bones.
Lt. Dangle
Originally Posted by ussi
yeah no drawbacks of the RSB... go with energy suspension bushings.
this was my first mod and yes i felt it i was really excited when i first took a curve @ 70 whereas befor i could only pull 50-55 on the same curve now i just need to give it a lower center of gravity by putting on some c/t sport springs
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
