coilover question
coilover question
been searching for couple hours now researching on 3G TL coilovers, out of all the coilovers i have seen and read about are ONLY spring preload height adjustable. unless i missed a few threads
my question is do any manufactures make fully independent coilovers, ones that have height adjustment doesnt depend on spring preload to lower. 2 different adjustments one for preload and one for height.
thanks ahead of time
Jay
Jay
the spring perch- bottom mounting plate, is on a threaded shaft- you set it and lock in place before driving and is usually left alone
The Tein SS and some others have a single adjustment for both dampening and rebound rate, thats how you soften or stiffen the suspension
Its located on the top and is a knob or tool insert into the top of the shock
check the Off Topic section Sponsored Sales for our vendors with all the things you need
ill look around more thx
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 07:42 PM
