CL Wheels on a TL S ?????
Can the CL S wheels fit properly on a TL S? The only difference that I can determine is the CL wheels are 7 inches wide and the TL wheels are 6.5 inches. The tires are exactly the same, so I presume the transition would be rather seamless.
I am concerned that there may be some ill effect, such as rubbing, or some mechanical malfunction, etc. Since the rims are wider, I presume that the offsets will be different.
Mark
Mark
Moderator Alumnus
CL-s wheels will fit just fine on your TL-s. Although the width is .5" wider, the offset remains the same at +55.
I currently have CL-s wheels on my TL-p with 215/50-17 Proxes T1-S and have no problems whatsoever. Good luck.
JByron
01-08-2016 09:49 PM
