caster adjustment on 06 tl
Bought new Michelin pilot sports, car pulls to the right ,had an alignment and found caster is off still pulls ,slightly, told there is no caster adjustment on acura tl, question?? is there a caster alignment kit avialable to fix the caster? , shop wants to heat up struts and bend to fix caster.thanks in advance!!
Diamond Pearl Dude - You're referring to camber. Camber/Caster are NOT adjustable on most stock Honda/Acuras. There are many aftermarket camber kits available (Skunk 2, Ingalls, SPC, and no-name brands) and can range from anywhere between $140+ for a pair of 2. I have Skunk 2 upper control arms in the front and SPC ball joints in the rear that cost me about $400.00 + the custom alignment.
BTW, if you go anywhere and they say they're going to heat up your struts/shocks, stay away from that shop. NEVER heat up struts/shocks because it will ruin them.
8th Gear
Im sure he IS talking about caster. camber doesnt produce pull. I have an 05 accord and my bushing was bad on my lower control arm and the caster was out of spec and it produced a pull. My friend lowered his cl and found out his lower arm was whacked and his caster was way out of spec and needed replacing.
On the other side. Camber kits with offset balljoints such as jpower and ingalls will let you play with camber/caster to a certain degree.
If number 10 is bad then you found your issue.
Toe does not produce any pull. If toe is off, the car will still travel straight but with horrible feathering tire wear.
However, you are right about caster pull. It will pull more towards the negative side but caster for the most part is not adjustable unless you have some sort of customization. You only have so much "play" when it comes to caster w/o it effecting anything else such as toe or camber.
06 Anthracite TL
OK, I can comment on this as I had a recent problem with a tire pull. I have a relatively new set (5K miles) of Conti DWS on all 4 corners. I had a slight pull to the right so I had 4 wheel alignment done as well as a tire rotation. After the rotation, the pull actually worsened. I was told (and also read on the net) that sometimes a radial pull is from a manufacturing defect in the tire such that all of the radial belts are not aligned properly during production . One way of correcting this is to switch left to right and vice versa the offending tire. In some cases, this can result in a pull the other way. In my case, it corrected the problem (now no pull and tracks straight). If it doesn't, replacing the tire would be needed. I was told (at Goodyear) that this happens more often than you would think, sometimes requiring replacement of the affected tire. The only case where this won't work (switching left to right) is if the tires are directional. Also, camber and caster are not adjustable on the TL, only toe.
Did this start when the tires were replaced? I would definately go with the tire theory.
As for caster being off, how well does the steering wheel self center after taking a turn?
I have the same problem. The mechanic i went to said it was too low so there is a kit to adjust them. I went to Advanced Auto or Autozone may have the caster kit to fix them but i just bought the car and it doesnt have aftermarket camber kits so how do u adjust stock camber kits?!?!
ScoobyZINE
I have the same issue of the car pulling to the right... i have my car slammed on teins and have ingall camber kit..... when i did my alignment the guy said that i had a bent control arm.... could that be the issue????
