Camber arm help
Old 09-21-2014, 04:24 PM
chrisd421's Avatar
Camber arm help
I just lowered my 3rd gen tl with tein s tech. i did the skunk 2 upper arms in the front and I ordered the spc arm for the rear. Unfortunately they didnt tell me the rears were individual so I have to order another one. My question is do i only need the one arm in the rear? I bought the spc arm but a friend of mine that had an 08 tls said that he had to replace multiple arms. I want to make sure I onlt need the one arm with the ball joint before I place my order for the other side. thanks in advance
Old 09-21-2014, 06:01 PM
nfnsquared's Avatar
Received 1,795 Likes on 1,348 Posts
One per side:
https://acurazine.com/forums/tires-w...t-boot-886608/
Old 09-22-2014, 09:51 AM
Former Sponsor
ExcelerateRep's Avatar
If you're just replacing that upper arm then it's one per side. But if you're replacing the 2 lower arms which is the better way to do it, then you need to replace two arms per side. That install can be a pain in the butt as the bolts in the lower arms tend to be frozen on most vehicles.
Old 09-22-2014, 11:09 PM
nfnsquared's Avatar
Totally disagree. I have yet to see a satisfactory set for the lower arms. Ingals certainly has issues as experienced by more than one Azine user. The SPC are top notch IMO. I wouldn't touch the Ingals set....
Old 09-23-2014, 12:40 AM
chrisd421's Avatar
thanks for your help... I ordered the other spc upper arm today and will be putting it in this weekend. I'm sitting at -2.5*
emailnatec
29
09-28-2018 04:27 PM
adreano17
09-29-2015 08:48 AM
0opie
09-22-2015 04:15 PM
Quick Reply: Camber arm help
