Biggg problem!!!!
ACTASY
Biggg problem!!!!
take a look at this and let me kno what you think!!!!
As you can see its only seperating on half of the tire not all the way around WTF!!!
Dude, this exact problem happened to me too, on 2 tires, both on the rear, apperently, it was due to lack of tread and cornering hard, causing the tread to seperate and having the belts exposed, hope this helps
ACTASY
so you dont think its front rubbing? because my car hasnt been rubbin....i was very shocked when this happened....my wheels are balanced and im gettin a bad vibration around 65 70 does any one have a solution?
AZ Community Team
Received 7,771 Likes
Looks cut. Usually from rubbing.
Otherwise -
Otherwise -
well from the spec on the tire it doesnt seem to be the wrong setup....that seems really odd.... check the ball joints top n bottom by moving the tires in up n down side to side in n out movements. all of those movements are supposed to solid if theres play theres a problem. check the control arm where it connects to the sub frame for cracking or seperation in the rubber.
Under construction
Honestly, that's why I never bought kumho's again. I had them once and that shit happened! I know alot of people like them cuz they are cheap, but this is what happens when you try to cut corners.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
