Balancing
Balancing
I had the tires taken out from my old rims which weren't shaking at all and now i have the tires on different wheels which shake a lot at 75mph, now my question is if i put the tires back to the previous wheels which weren't shaking do they need to be balanced again? or not?
Won't have to rebalance your tires to mount them again.... Did you get aftermarket wheels? If so did they place hubcentric rings on it? and did you use aftermarket tuner lugs? If not thats why you have vibrations most likely
iScrape going into
Hmmm sounds like a balancing issue, did you get get them road forced balanced I'd recommend getting that done. Also like Fulani said do you have aftermarket wheels? Do you have tuner lug nuts or hubcentric rings?
You really think so? Because that is good news i don't want to pay for balancing again. Yeah i got used aftermarket wheels from a member here but he didn't have the hub centric o-rings and i don't want to buy new ones for those wheels because they aren't worth it to keep.
iScrape going into
My Garage not
1 Post
hubcentric rings cost <$15.
if those don't work get the wheels rebalanced on a hunter machine and check to make sure the lug nut seat is the correct shape.
iScrape going into
Should of clarified it depends what kind of hub rings you get. The rubber ones are cheaper and do just as good as job as the metal ones. I prefer the rubber ones because the metal ones are known to seize to the rim.
yeah i think it's the orings that give me the problem, but i rather go back to my old rims because the ones i bought were advertiesed wrong to me and they are heavy and not in good shape basically i got ripped off but it's good thing i paied only $400 for those rims.
/\/\/\ i don't want to mention any names but they are mile migelia rims so i don't get it do they need to be balanced again or not? Can someone give me straight answer cause i don't want to pay more money to the tire shop.
joflewbyu2
10-08-2015 11:16 AM
