Anyone running 40's on 19in wheels
I know it may be a stupid question to some BUT ive done some researche on the forum to find this out but no luck.
So i wanna know if anyone tried out some 40 series of tires on 19 inch wheels with success or if it doesnt fit at ALL
thank you
thank you
it'll be rubbing like crazy and probably the tire would get shreded by the fender. Bt it all depends on offet, rims zies in with and tire size
re
One good thing if someone has this setup to comment if its going well for him or it was a big NO NO, i just wanna know for sure and not buy some 40's and get it in the teeth, cus some of the roads in my area are not too safe to protect some nice wheels
thank you for your understanding
this setup can be a big hazzard to you becuase the diameter diffrence is larger than 3%. That may cause brake failure, very inaccurate speedo readings along with navi problems and some other electric issues such as MPG or range calculators. Here are the calcs:
http://1010tires.com/TireSizeCalculator.asp
these are some calcs of what you wanted and the last is one tire that would work:
'06 750Li Sapphire/Creme
Originally Posted by HQTL6SPD
anybody ever try 19 x 9.5 inch wheels in the front with 255/35/19 tires? too wide, am i correct?
I guess that will do, the rims i want are either 8 or 9.5. I'll get the 8" with 245/35/19 summer performance tires. I just need to start saving up... BTW Thanks
No problem. I ran into the same thing when I was making the decision. There is another post where someone is trying to pu 9.0" all the way around and one guy in the gallery section says he has 20x9.0's but we don't know any of the details behind that particular install (if it worked out long time or what he needed to do to accomplish it).
mada51589
05-03-2022 08:54 PM
nuldabz
09-03-2015 05:49 PM
