Anyone running 18x9.5 in the front ?
Old 12-11-2010, 10:50 AM
jimmy954's Avatar
i was interested in getting some new wheels again and was wondering if anyone was running 18x9.5 all around or atleast in the front.
the wheel specs are
18x9.5 +48 2.75in lip all around
i already have the rear fenders rolled what would i have to do on the fronts to make them fit i was planning on running 225/40/18 front and 235/40/18 in the rear since i have the extra tires laying around
also i am dropped about 2in in the front and 1.75 rear on h&R springs with tokico blue struts
thanks for your input !
pics are also very helpful !
Old 12-11-2010, 11:26 AM
myron's Avatar
there are a few guys that are running 18x9.5 all around but with +22 or +15 offset. Wheels stick out pretty far out. With that offset they don't seem like they would stick out but might have problems clearing brakes if manual or maybe hitting the suspension components. I am not too sure about this but it's worth looking into befor e purchasing the wheels
Old 12-11-2010, 12:58 PM
jimmy954's Avatar
im riding in an 05 base model 5at with navi so no 6spd i just dont know about clearing all the components and i dont really wanna run spacers cuhs i dont wanna poke out
Old 12-12-2010, 12:41 AM
Herro
NBPacuraTL's Avatar
my rpf1's were 18x9.5 +38 all around w/ 235/40/18's and didn't had an issue with rubbing unless I was fully turned on a steep incline. I was a little lower than you.
Here's a picture of it when I slammed the car a couple years back.
And here's a couple of pictures before I slammed it.
Mind you, 18x9.5 +48 will have 10mm more clearance from the outside but 10mm less from the inside. Not sure how close that'll be to your suspension up front. Might want to check on that. Btw, in those pictures, I didn't roll my fenders.
Old 12-12-2010, 11:59 AM
Italiano's Avatar
Im running 18x9.5 et 38mm lowered 2 1/2 inches. No rubbing. Rear fenders rolled as well. Running 235/40/18 Next set of tires will be 245/40.
No reason for you to run 225 Go with at least 235 series
Uploaded with ImageShack.us
Old 12-12-2010, 12:21 PM
Stand For Something
ASASN21's Avatar
I'm running 18x9.5 +35 235/40 tires and have no rubbing issues at all. Didn't roll my fenders either. To be honest I think the +48 is going to cause problems on the inside rather than outside.
Old 12-12-2010, 01:35 PM
pearlite TL's Avatar
Im running 19x9.5 +30 in the front with rolled fenders dropped 2in and running 235 35 and have no problem rubbing at all....18x9.5 shouldnt be a problem
Old 12-12-2010, 04:05 PM
jimmy954's Avatar
thank you for the pics i love the your car NBPacuraTL
should i run spacers ? if so what should i run ?
Old 12-12-2010, 05:32 PM
myron's Avatar
should probably run 15mm spacers.
Old 12-12-2010, 10:22 PM
jimmy954's Avatar
That's what I was thinking 10 or 15 do you think 10 would be ok ?
Old 12-12-2010, 10:38 PM
Stand For Something
ASASN21's Avatar
10mm in the front, at least 15mm in the rear. Personally I would go 20mm, especially since you're running stretched tires. And don't run 225s in the front, 235 will be fine.
Old 12-12-2010, 11:19 PM
myron's Avatar
+1, that +48 offset is really weak
Old 12-12-2010, 11:39 PM
bforbrian's Avatar
18x9.5 +45 with 275/35-18 all around.
18x9.5+22 with 225/40-18 all around.
Old 12-12-2010, 11:51 PM
Gimpster621's Avatar
did u have to do any fender work with the te's? what suspension are u running?
nice setup!
Old 12-13-2010, 12:05 AM
bforbrian's Avatar
nice setup!
Just rolled rears; i'm on tein basics.
Old 12-13-2010, 11:53 AM
jimmy954's Avatar
bforbrian both setups are pure sex =D
do you still have the rpf's for sale ?
Old 12-13-2010, 03:34 PM
AtlM5's Avatar
Just the kind of setup I was looking for...very nice!
Old 07-27-2015, 08:49 PM
champaned_out's Avatar
Didn't want to make a new thread so I'll just ask here and bump this one up
I'm looking into some 18x9.5 +22 for all 4 corners, I am currently dropped on tein s techs and I have about a 1 to 1 and half finger gap all around.
Would I be able run these wheels without rolling or pulling my fender or quarter panels? And if I can run this size wheels what tire size would be best to make sure I minimize any chance of rubbing?
Old 07-27-2015, 09:19 PM
TonyN923's Avatar
you wont have any problem with your 18x9.5 +48 and 225/40, im 18x9.5 +45 front and 18x10 +42 rear with 245/40 all around and dropped on Tein S-Tech, zero problems and no fender mods. Your good to go.
Old 07-27-2015, 11:01 PM
last post before mine was 5 years ago
Old 07-28-2015, 08:52 AM
Andrew
VisualEchos's Avatar
Holy thread bump lol. 18 x 9.5 is easy cheese these days.
Old 07-28-2015, 09:48 AM
Received 16,260 Likes on 11,971 Posts
lol
Old 07-31-2015, 03:00 PM
story.customz's Avatar
I'm running these specs with 225/40 F, 235/40 R
Fronts rub only on steep inclines with the wheel turned.
Rears rub on big dips, so I'd suggest 225/40 square.
I'm dropped quite a bit though, if you're running stechs you should be fine.
champaned_out (08-01-2015)
Old 08-01-2015, 03:15 PM
thanks for the tip!
02-25-2020 09:57 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
PortlandRL
09-14-2015 12:01 PM
08 NBP TL
09-08-2015 08:49 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Anyone running 18x9.5 in the front ?
