All-Season Recommendations
My normal response is to recommend 245/45-17 and to take a look at the survey. If you need tires for snow travel look at that category:
http://www.tirerack.com/tires/survey...ireSearch=true
If not used in winter look at the Yokohama W4s 245/45-17 with an exceptionally wide tread and reasonably priced. Although they are classified all-season tires, most UHP tires leave a lot to be desired in the snow. Quite a variety available from @ $80 to $200.
dont get the mxm4's...they come stock and are rated good BUT SUCK BALLS
friday morning coming home from work, took a ramp to get on parkway, roads were damp, no puddles anywhere, when its dry i always take the turn around 50-55, the sign says 25, i was going around 35-40, and tried to turn and nothing happen, kept going straight LOL. pulled the e brake barely(maybe ~1" up and for about 1 second) to get the car to "drift"(and slow down) then caught alittle traction and everything was good
anyway falkens are definitely very good
The mxm4's are very expensive. I got a set of Michelin Pilot A/S for $108 each from tirerack.com With shipping they were around $500 for four, then about $224 for mounting, balancing, and alignment.
Head a da Family
http://www.goodyeartires.com/goodyea...ea=Performance
On my 2nd set and I buy them again in a heartbeat.
emailnatec
29
09-28-2018 04:27 PM
adreano17
09-29-2015 08:48 AM
