Alignment Specs - Help!! After 2 new Tires on Front (Continental DWS)
Just got 2 new tires put on, Continental DWS on a TL 2005. Had them put on the front and the front tires rotated to the back.
Dont know how to post attachments, so here are my specs below. It feels great...my only big concern is the steering wheel feels considerably "looser" now---like when I turn, it's as if I have to turn it more than I used to. I don't like that...is that something I can go back to them with and they can easily adjust? I assume something with the new tires or alignment changed it. Before I just minutely turned the steering wheel and the car/tires responded/moved, which feels proper to me.
Thanks for your input!
FRONT
Cross Camber - Actual: 0.4 Before: 0.4 Specified Range: -0.8 to 0.8
Cross Caster - Actual: 0.0 Before 0.0 Specified Range: -0.8 to 0.8
Cross SAI - Actual: -0.6 Before: -0.6
Total Toe - Actual: 0.02 Before: 0.05 Specified Range: -0.16 to 0.16
REAR
Cross Camber - Actual: 0.5 Before: 0.5 Specified Range: -0.8 to 0.8
Total Toe - Actual: -0.01 Before 0.14 Specified Range: -.16 to .16
Thrust Angle - Actual: -0.01 Before -0.07
Of Special Note...
Rear: RIGHT
Camber - Actual: -1.5 Before: -1.5 Specified Range: -1.5 to -0.5
Toe - Actual: 0.01 Before: 0.14 Specified Range: -0.8 to 0.8
If any other info is needed please just let me know.
FRONT
REAR
Of Special Note...
Rear: RIGHT
What are the final camber and toe settings for each wheel, e.g. LF, RF, LR, RR?
The DWS tires leave a lot to be desired because of the soft sidewalls. Don't know what tires you had on the front, but new tires should be placed on the rear. May want to up the tire pressure on the DWS.
Front Left:
Camber - Actual: -0.3 Before: -0.3 Specified Range: -1.0 to 0.0
Toe - Actual: 0.04 Before: 0.01 Specified Range: -0.08 to 0.08
Front Right:
Camber - Actual: -0.6 Before: -0.7 Specified Range: -1.0 to 0.0
Toe - Actual: -0.02 Before: 0.05 Specified Range: -0.08 to 0.08
Rear Left:
Camber - Actual: -1.0 Before: -1.0 Specified Range: -1.5 to -0.5
Toe - Actual: -0.02 Before: 0.00 Specified Range: -0.08 to 0.08
Rear Right:
Rather than repeating myself:
http://www.tirerack.com/tires/tirete....jsp?techid=52
Numbers aren't incorrect, but I always like to have the toe equal on each side e.g. front the same each side, rear the same each side. They have the rear total toe pretty close to zero.
Right rear is at the max camber but only .5 degree difference from left.
Should be fine. Change the tires around (Front to Rear)and see if any difference or the rear then feels squirrely, if so, tires.
Why should the new tires be placed on the rear? They recommended I put them on the front, stating because it's front wheel drive. I could always rotate them, just let me know what's best.
Front Left:
Front Right:
Rear Left:
Rear Right:
Front Left:
Front Right:
Rear Left:
Rear Right:
It's fairly standard for the TL's rear camber to be at or even slightly more negative than the maximum negative spec (-1.5 to -2.0).
The DWS' do have softer sidewalls and will have a different feel in hard turns. Be sure you have them properly inflated to OEM specs and I'd move them to the rear or match the tires on all 4 wheels.
Those specs are fine. Camber and caster are not adjustable on the stock suspension. If caster is out of spec, you likely have a frame/suspension component issue.
Level: Noob
Is there anyway to adjust the alignment myself? I had a tire replaced yesterday about 2 hours after I got an alignment, and after the tire replacement my car pulls haaaaaard to the right. Can I fix this myself, or do I have to pay 75 bucks again? :/
Level: Noob
They put the new tire on the right rear. Last night, I checked the tread of each tire, put the new one on the left front and moved that one to the right rear, it didn't change the pull at all.
Alignment
Thanks,
nuldabz
09-03-2015 05:49 PM
