Alignment specs for 20's
i have 20's on my car and its not lowered but i have a stereo in the trunk. my tires are 225/35/20 and i had the car aligned completely back to all zeros. I have 3400 miles on these tires and the insides of the rear are almost gone when i did my first tire rotation. Would my stereo be affecting the weight that much in the rear? does anyone have some alignment specs they can share so i can fix this problem? this is my 3rd set of tires.
it will not let me load an attachment pic of my car so here is a link
http://a3.sphotos.ak.fbcdn.net/hphot...00000549843500
^^^^sorry that was a fail
http://a3.sphotos.ak.fbcdn.net/hphot...5_198023_n.jpg
If you had the alignment done with all the equipment in the car, it should be good to go as long as the alignment equipment was calabrated correctly and the tech knew what he was doing. If done before any heavy weight was put in the trunk and set properly, the rear tires will then toe in and camber wiil go more negative as weight is added.
Post the specs if you have them.
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
