Alignment HELP
2007 CBP TL|FF2'S|
Alignment HELP
just slammed my 07 tl on ff2's can somebody anybody help me wit a set up on stock wheel without massive tire wear???
im new to all of this still so bare with me guys tks
Got to sit tight and let the people answer as there is no sense in repeating a post every hour or so.
To answer your question, if you're slammed, I'd say no, there are no alignment specs that will help as the only adjustment is toe, so best to install camber kits and then get the alignment done. Do it right.
Don't create two threads about the same thing
I agree with what Turbonut said. You need to get an adjustable camber kit (Ingalls is used by many people including myself) and make sure your toe is in check.
"Slammed" and "preventing massive tire wear" aren't really used in the same sentence You need to get an alignment but after you do, but either you leave the ride height where it is and potentially chew through tires or you raise the car up some and get the specs back in check and save your tires.
2007 CBP TL|FF2'S|
thanks for your help bro. Im new tomposting things wasnt sure if it worked lol. bare with me guys lol. thanks for the help. nobody around here seems to able to do nething for me say my car to low.
No worries man, I was just giving you a hard time
I'm not close to being as low as you are and I have problems too. Gotta pay to play I guess.
nizzle902 (09-06-2012)
emailnatec
29
09-28-2018 04:27 PM
Zonian22
11-14-2015 01:20 PM
