Alignment help...
Alignment help...
Guys,
I need some help. Could someone who's versed in this sort of thing do me a favor and check out my alignment numbers? I have an A-Spec TL 05.
I just plopped on 19s and want to make sure my tires don't wear out prematurely again.
Any help appreciated!
Thanks!
Collin
Thanks!
Collin
06 TL 6spd. Navi/A-spec
You should have no problems! All the toe when you started except the right rear was out a little, now everything is green. Toe is the only thing that you can adjust on the car without any aftermarket kits. Your camber is in the green so you should have no inner tire wear!
Thanks! Strangely my last set of tires were mostly worn in the inside (rears). I'm planning on rotating a little more often to see if that helps any, but I doubt it.
Thanks again, that eases my mind.
Originally Posted by 260 HP
The right toes (front and rear) are too close to the limit for me. A little swing and you're out. I'd like to see the numbers closer to 0 (F) and 0.04 (R). It's just me, though.
emailnatec
29
09-28-2018 04:27 PM
