Advice for wheels and tire set up
Alright guys I just got a silver tl type s and I'm thinking about getting some of the varrstoen wheels not quiet sure if I want 18's or 19's and I don't know what kind of offset setup to get if anyone has any suggestions that would be cool
In any size, 18 or 19, you can go in a 9 width and a +35 offset. You will not have to use camber kits or roll the fenders. And you will have no rubbing problems. If you want to go safer, go with a +40 offset.
^ VarrsToen does not offer wheels with high offsets they offer aggressive fit wide rims that when fitted properly look hawt however if you want to run a proper set you will have to do fender work, you will have to run camber and you will have to stretch tires...
here is a chart of the styles they offer and the sizes/offsets available
http://varrstoen.com/2011%20VARRSTOE...ART%20v3.0.pdf
if you try to run an 18"x9.5" +30 or in a 19" form the rears would work good with a fender roll and a 235/35/18or19 would work good but the fronts will be some work to fit and you would need to run most likely a 225/35/18or19 rim
this place carries some decent knock offs with a little more usable offset and rim width range for the TL
http://www.wheeldude.com/catalog/index.php?cPath=335
braveheart
09-07-2015 08:12 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
