Acura Tsx Rims/acura Tl 6spd
Does anyone know if wheels coming off a acura tsx will fit a 04 acura tl 6spd, I believe the tsx rolls on 5x 114 bolt pattern. or does it have to be 5x114.3
Someone is selling someone wheels that are coming a tsx.
I didn't notice the 6 speed. That will be a problem! As for PCD lug pattern, bore and thread pitch, the TL and TSX are the same.
When I asked tire size I meant width also. Is the TSX 18" tire 215, 225, 235 width? Anything under 235 will look small on a TL.
I have 245/40/18" on my 07 TL-S. Perfect fit.
You'll want to know what the wheels offset and width. Wheels that fit perfectly on a TSX won't fit as well on a 3gen TL because TSX needs higher offset than the TL.
The TL and TSX have the same overall diameter tires.
Plus if you're on 6MT, you'll have to make sure the spokes will clear the calipers.
acura_dipset_tl
01-01-2016 03:02 PM
nuldabz
09-03-2015 05:49 PM
