Acura TL with OEM style wheels
#42
Has anyone else done this before? As in running those BMW 7 series style 95 wheels, on the previous page?
I've been looking into finding them but Not sure if crazy work is needed or not, and no way I'm going to run neg -6 deg of camber like that guy did, or well at least I wont have to lol. Trying to get some more information for these wheels on TL's!
#43
I'd love to see the 335 sedan wheels on a 3G.
I considered for a while, the infiniteeiy wheels, but in the end, I couldn't get past the fact that I would be spending over a grand to put another company's oem wheel on my car and people that know the car would know the wheel doesn't "belong".
I know it shouldn't matter, but let's face it, we all notice when that 40 year old goes to the gym with adidas shorts, nike socks and mcgregor shoes.
Slpr04UA6 (07-08-2013)
#44
#45
#46
By searching on Google for 2 minutes, I found this information:
19x9 front
19x10 rear
+24 offset
5x120 bolt pattern
So with that information now known, you would have to get the wheels redrilled and then run either a 215 or 225/35/19 tire up front and probably a 225 or 235/35/19 in the rear depending on how low you are.
19x9 front
19x10 rear
+24 offset
5x120 bolt pattern
401tuner (07-09-2013)
#47
19x9 front
19x10 rear
+24 offset
5x120 bolt pattern
19x9 front
19x10 rear
+24 offset
5x120 bolt pattern
Thanks man, it's appreciated! I know all the specs on the wheels, was just hoping someone could chime in who has run them or knows someone who has? To see what needs to be done to get them to fit, and fit right. I am on Tien SS Coilovers currently with rear fenders rolled (nothing crazy). But just didn't know if there was anyone out there who had ran them before or knew anyone who did who could give some input on what they had to do.. if camber kits needed, or pulling/flaring fenders, crazy amounts of neg camber (hopefully not), best to run them as the staggered set or just run 4 fronts so all 19x9.. stuff like that? Thanks in advance if anyone can give input!!
#48
KCCO
#49
#50
3G TL bolt pattern is 5x114.3
4G TL bolt pattern is 5x120
They will fit if you run adapters.
#52
Any idea if these are redrilled or if wheel adapters were used? I wonder if a 1" thick adapter will fit. The wheel has a 55mm offset, so 55-25.4 = 29.6 which is about a 30mm offset right? Do you think I would be able to run 235/40R18s on an 06MT without modifications (such as fender rolling)?
#54
I have these wheels with adaptors but the studs are M12.
Are you using the original Acura to m12 lug nuts with the wheel space wobble?
nanos
11-12-2015 08:41 PM
