9.5 wheels with 35 mm offset?
Purely speculation on my part as I judge every possibility based on the OE wheel position, and have never installed this combination. Having said that, the 9.5" +40mm will move the wheel out @ 15/16" and that would put the wheel at the outer edge of the 1/4 panel, and in the front, the outer edge of the wheel would be beyond the fender. Now if you add any tire of substance to the wheel, it will be out even farther.
Once again, not an attack, just need some reasoning. Is there something I don't see.
94 DC4 RS LSV/Turbo
your calculations are incorrect
18x8 +45 (18" optional wheels) wrapped in 235/40-18
18x9.5 is 1.5" wider overall but it is .75" on the outside and inside
255/35-18 is 20mm wider... BUT it is 10mm on each side 10mm is like .4"
40 offset is 5mm wider which is .2"
sooooo.... 1.35" closer to the fender... makes sense? hope so
the way I see it, 9.5"-8" = 1.5" (0.75" on each side wider than stock)
Then offset difference is 5mm because it's not added to inside and outside just the outside compared to stock.
so the wheel is out 24.05mm I don't know about the tire, but adding the difference on top of the final width of 24.05 doesn't make sence to me.
94 DC4 RS LSV/Turbo
My calculations without the tire is right on at 15/16" .9375", which is your .75 plus .20, but then if you add the 255 tire you'll add .4 which moves it up to 1.35", but how can that fit under the TL? If added to the factory tire, the assembly will be outside the body by about 3/8", as I can see no other explanation.
Yes, your 9 x 25 moves the wheel out 1.30" and at least on my TL the wheel will be outside the 1/4 panel.
Some of the guys that have a stock TL, cut a straw, or something lite, to the length of 1.3" and put that up against the upper part of the wheel and see how far out the wheel in question will be, not even including the tire. It will be interesting.
nuldabz
09-03-2015 05:49 PM
