40mm offset?
Old 03-22-2002 | 08:38 AM
shimbo519's Avatar
USMC Butterbars
40mm offset?
Will 17 x7 with 40mm offset work with H&R sport springs? Will it look wierd?
Old 03-22-2002 | 10:59 AM
TypeSDragon's Avatar
Loving my 08 TLS!
it will rub. Get something with a 48 offset and you be ok.
Old 03-22-2002 | 02:38 PM
wiggingboy's Avatar
i think those offsets are for lexus..
Old 03-22-2002 | 10:05 PM
amir was here's Avatar
that will fit.
its a 7" wide rim.
my rims on my CL are 18 x 7 with a 42 offset, and 1.5 inches dropped.
the setup you are getting will extend outwards the EXACT same as a rim that is 7.5 inches wide with a 46 offset(odd offset)
I have seen people on this board with a lower offset than 46...i've seen 45 offsets on a 7.5 inch rim, and i've even seen a 42 offset with a 7.5 inch rim....but with rolled fenders on the 42.
heres a good link,
http://toy4two.home.mindspring.com/offset.html
Old 03-22-2002 | 11:45 PM
Lawaia's Avatar
Moderator Alumnus
The fit is marginal...may require a clip and trim here and there depending on the tire size you go with.
As for look, they'll probably make you car look wider (not sure if that's a good thing).
Personally I would not go with anything less than +45 offset. Good luck.
neuronbob
23
07-16-2019 10:48 AM
BreezyTL
07-26-2016 12:52 PM
SinCityTLX
55
10-11-2015 01:20 AM
Ratheruneeq
09-28-2015 07:41 AM
bailey24
08-31-2015 05:38 PM
Quick Reply: 40mm offset?
