245/45/17's on OEM rims...
Just ordered 245/45/17's (stock 235/45/17) to put on my OEM rims...have heard differing opinions on yes/know regarding rub...
I have no suspension changes, Ferman Acura seems to think it will be OK...as well as the guys at tires.com ...any opinions?
Is there anyone else out there that has done this?
I am installing them tomorrow, so I'll let you know.
Crossing my fingers.
I just installed the 245s on my 05 TL - with no rubbing whatsoever.
10mm is only about 1/3 of an inch - nothing to worry about.
(they do help to fill out the wheel wells much better)
Thanks, guys, installed them yesterday.
It feels as if I have a NEW car!
OhmyGod, what a difference...it tracks straight, quiet to 120+ (I know, I know), and hits the bumps a little "quiter" as it is...
Thanks for the input; I looked up the answers to this thread immediately before I gave the installer the "OK" at the shop, so this just goes to show you that there is a definite usefull utility to this forum...
-L8R
-L8R
Team Anthracite Member
What PSI are you using?
32/32 or higher?
32/32 or higher?
-L8R
-L8R
The Flipster
I purchased new Michelin Pilot Sport A/S 245/45/17 on stock rims. Have to agree....rides like a new car. Didn't reliaze how bad my EL42's had gotten. Any who I cannot get the 245's to rub at all.
Originally Posted by yendor
Just wondering. Any problems with cars equiped with factory navi with the accuracy for the GPS that relies on some inertial navigation for feedback?
New 235-45/17 circumference= 79.6"
New 245-45/17 circumference= 80.7"
Error introduced= 1.4%
New 235-45/17 circumference= 79.6" (11/32" tread depth)
Worn 235-45/17 circumference= 78.2" (3/32" tread depth)
Error introduced= 1.8%
In any case, the inertial navigation kicks in when the GPS receiver doesn't have a good view of 3 or more satellites like when you're driving through a tunnel, parking garage or city with tall buildings. Over the course of a mile the error due to tire size would only be about 75 feet.
(Yes, I am a math geek to take the time to figure this out.)
WDP Director of R & D
Greetings all,
Thought I would chime in here... I just ordered a set of Michelin PS2's (245/45's) for my 04 5AT tonight - couldn't wait another mile.... I have less than 15K on the EL-42's and the flatspotting and vibration is just horrendous. I probably made "the bad" tires even worse by having my car in storage for several months due to being out of the country lately. I've been driving it at highway speeds/commute for a week now and the flatspots will not go away.
In all reality it just helped push me over the edge to order the Michelin's.
-- After checking the specs the 245/45 seemed like the way to go. Thanks all for the above info/peace of mind. I too am looking for a little extra tire width/rim protection, not to mention a smooth ride for a change..
Cheers
Cheers
I am looking at replacing my oem 10k mile el42s.
What advantage to the 245 vs 235's give me?
Only more rubber on the road?
Do they do anything at all to better protect the wheel rim edges?
Do u think they are worth the few $s more as compared to the 235's?
thanks
thanks
anytime. hope i helped.
eeewww. they really are bad tires. i thought they were "acceptable" touring tires until i replaced them and realised what absolute sh*t they are.
this is a good thing, 'cept in snow and water.
absolutely. this is the primary reason for spending the extra money.
the 245's are cheaper than replacing rims damaged by curbshots.
>thanks
>thanks
thank u!
245's it is
answers like that are an example of what a great forum this is
245's it is
the EL 42 robs 2 inches off our tire width
Looking through the Specs of the EL42 tire compare to other tires and i notice something weird. 235/45/17 has 9.2 sect width (widest part of the tires ) and 7.2 for the treadwidth which is almost 2 inches smaller. No wonder why our rims scatch so easy. Compare to the new Firestone wide oval /RE750 with 9.4 sect width and 8.1 treadwidth..much more rubber given the same side of tires..The yoko avs 100 side wall seems to be the most straight so you get the most treadwidth on the road...Looking at the EL42 you can really tell the side wall curves in at the contacting surface..
I went with kumho ecsta asx 245/45/17 tires. The larger size has better rim protection and the softer tire made a big difference in the ride - easier on the divider strips and bumps in the road and the handling is still just as responsive. They look the same from the side but have a wider, more muscular look from the front and rear. I would highly recommend them, especially in the 245 size.
Originally Posted by TampaMike
What tires did you settle on?
BTW, The CSM at Ferman, Brian is my neighbor...good guy.
thanks
thanks
No rub, fill the wheel openings better.
As far as protecting the wheel more than the 235s - hard to tell at 1st glance - but at they appear to at least offer some protection for a slow "flush" w/ the curb brush.
I have driven on the new tires for only about 50 miles so far.
but the ride seems less harsh on rough roads.
Handling - where the el42s would squeal in protest on a fast turn - the Pilots just hang on.
The main reason I replaced the oem el42s was - they scared me in rain.
No rain yet to tell, but at wet intersections pulling away from a light that just turned green - the Pilots just pull where I know the el42s would just spin (even when new)
With the oem tires I could only enjoy the car when the roads were dry.
The sight of rain drops in the windshield would make me cringe b4
only wish the tires where orig equipment
Don't forget to check the weight of the tires before you purchase.
My 245/45/17 were listed as being .5 pounds less than the stock 235/45/17 EL42. Some of the 245' options were up to 5 lbs heavier ( each ) than stock. Thats alot of unsprung weight to add to each corner.
Originally Posted by TLTrance
Can anyone post side by side pictures of the stock 17" wheel, one with 245/45 and the other with 235/45?
It would help me decide on this as well...
Originally Posted by stevelit
I dont have before and after pics, but the 245 Kumhos are 25.7" diameter and the 235 el42s are 25.5" diameter. You can't tell the difference in height. However, the 245s are 9.6" treadwidth and the sidewalls bulge a little (better rim protection) vs 9.2" tread and no sidewall bulge so the 245s are noticeably wider and look more aggressive. The 245s are 3lbs heavier but I didn't notice any difference in driving, just a smoother ride.
Just had my Michelin 245/45 Pilot Sport 2's installed. As Steve mentioned the width is the only "visible" difference (size wise), and it's for the better. Were not talking a huge difference either but about 1/4 of an inch of rubber past the rim.
The tire/size just looks right on the rim and within the fender. I wouldn't give a 235/45 another thought...
The best part, and a plug for Michelin,,,, The TL rides so much better with the PS-2's as it "may" with most tires besides the EL-42's. The PS-2's have absolutely no flatspotting and zero vibration (I've only driven to about 65mph thus far though).
My rims went from having 2.5 to 4 ounces of weight required to balance the Bridgestones PER TIRE to .25 - 1 ounce max on the PS-2's.
To put it bluntly: All 4 of the Michelin's combined took less weight than any one of my EL-42's!! Pretty obvious to me the quality control/construction process is much better on the Michelin's.
Hines57
09-24-2015 01:58 PM
