245/40r19..??
Offset. Bolt Pattern. Hub Bore.
We need sizes/specs on those three things as well.
The tire you're referencing probably has a 26.7" OD, so it's 1.4" taller. If you're not lowered, it'll fit. It's far from optimal, but it'll fit (provided all the rest of the wheel specs are in order). As Turbonut stated, the 245/35 is the better choice, with a general OD of 25.8".
