245/40R18 Users... What PSI?
Hey Everyone
Those of you with 245/40R18 tires, what PSI do you inflate to?
I am currently at 34psi, but if I inflate to 37-38psi will I cup the tires?
Make sure that you fill up your tires to around 40PSI and let the car sit overnight. Then in the morning let out some air to 37 or your desired PSI. I think 38 is going to be a bit to high and will cause wear on the center of the tread. To low and you cause wear on the outside edges (both) on the tire.
Cupping is due to a bad alignment on your car or bad suspension components.
packohotdogs (06-10-2011)
keep it clean
2016 E350 Sport
There is no way you should be using less than 37 psig for these tires. I will typically inflate to 40 psig in front and 37-38 psig in the rear for a FWD car (cold measurement). These tires will usually have a max pressure rating around 50+ psig so 40 psig cold is not an issue when warmed up to around 45 psig. Never had an issue with cupping or wear and I am fanatical about maintaining tire pressure. IMO, 35 pisg will provide little sidewall support for a low profile tire especially if you like the twisties. 35 psig will also make your tire look like it is losing air.
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
