2006 acura tl rim fitment
just wondering will any of these bolt patterns fit a 2006 tl?
18x7.5 4x100/4.5 18x7.5 5x100/115 18x7.5 5x4.25/4.5 18x7.5 5x4.5/120 thanks guys... |
https://www.wheel-size.com/size/acura/tl/2006/
5x114.3mm is the same as 5x4.5" But you also have to be sure about offset, hub diameter, and a few other measurements. 7.5" is narrower than the original wheels a little bit. If they're local, just test fit before you buy - get the front end up, swap the wheel on, see if it fits, put the car in neutral and spin the wheel around to see if it rubs, etc. |
