19x9 45 offset?
19x9 45 offset?
I'm thinking about purchasing wheels in 19x9 45 offset. I was wondering what the fitment issues are on this spec size and if there is anyone here with wheels in this size?
9.5+10.5 22m=Hella Flush
THose should fit perfectly and flush with the car. They are almost equivalent to my 19x8.5 with 35mm offset.
thanks for the inputs. 260hp, are those 19x9 in your avatar? and also, if i plan to lower the car w/ either a-spec or comptech springs (no lower then 1" drop), am i still golden?
On my car back then, lowered 1", nothing sticks out at all. The top of the wheels and tires are completely under the fender.
Of course, if your car is NOT lowered, they may look like they stick out a bit, because when the car is lowered, the suspension actually tucks in the top of the wheels into the fender a little. It's all due to the suspension range of movement.
19x9 at +45 ETactually sits a little deeper (3.75 mm, 0.15") into the fender compared to 19x8.5 at +35 ET. At this point, my car is lowered at 1.5" F and 1" R, and the wheels are totally under the fenders. So 19x9 with +45 ET should sit even deeper than that.
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
