i have 2002 TL-p with H&R sport drop..
will this 19x8 rims with +45mm offset and 225/35/19 tires work without rubbing problem?
do i have to roll or cut my fender?
thank you
thank you
Acura TLS are SLOW
NO! i have 19x8 with +45 offset on 225/35/19 and it does not rub AFTER cutting the tab on the rear bumper
Quote:
lowered?Originally posted by MotionEffects
tire brand/model?
camber kit?
It's Go-Time.
Running 225 rubber, with that drop and shaving the fender tabs - you should not rub.
i just replyed to the other but like i said before no you shouldn't rub i have 235/35 r19 with 45 offset an dropped. just cut the tab
by the tab, do you guys mean the 3 inches thats part of the rear bumper that you can see from the opposite side of the car when u raise it? Meaning like if you raise it from the front left, the rear right will be elevated enough to see and cut with dremel?
245/40/18's fit fine
245/35/19's will fit fine, not sure why you keep saying 225's
255/30/19's will fit fine
+45mm will work fine, but no more that +45.
