19x8 +50 questions
Registered Member
I don't know why you would want rims with a +50 offset. Stock is +45 and they are sunken in under the fender enough. +50 will look terrible, especially if you are going to lower your car. I would look for a rim with a lower offset. But if you stick with the 19x8 +50 a 215 or 225 tire would be best.
That wheel will move the tire inward 5mm (45mm OE to 50mm) or .20" slightly more than 3/16". Although I would rather stay with the factory 45mm offset, many run a 50mm offset, but with the OE or larger sized tires. Don't know why anyone would run a +50 and use 215 or 225 tires as it would certainly accentuate the "inward" movement.
If you like the wheels and at a decent price, you can always add spacers to move them outward, and 5mm spacers would be about the thickest that can be used without changing the studs.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
navtool.com
09-25-2015 05:15 PM
