19x8 rims with a +30 offset... how will they sit? Im rolling an 05 base, A-Spec lip kit and just installed new shocks and Tein S-Tech springs, so naturally, Rims are next. lol. Looking on Tires.com and checking out their TSW wheels, which in 19x8, can be purchased in a +30 offset. Will this work with my setup? My friend has the Eastwood Roller so rolling fenders is an easy step if need be. Any input or pics would be awesome! Thanks!
I was figuring that. Would all 4 corners need to be rolled or just rear? Other than the rolling, it should work fine though?
Im an idiot... "Will NOT need to be rolled". My brain isn't functioning at full capacity yet.. lol
Haha. Ya, im slow today. Anyway, thanks for the reply. I've been toying with what to get. Looking at the TSW Brooklands in silver.
The Machine
Registered Member
close
- Join DateDec 2011
- LocationSouth Jersey
- Age43
iTrader Positive Feedback100
iTrader Feedback Score(8)
Liked:802 Times in 578 Posts
I don't have pics, but I can tell you it will fit. Since you're not slammed because of only being on springs the +30 offset won't look too sunk in because there won't be much negative camber there.
Roll the fenders anyway. Even if it's not needed. You may want to change wheels donw the line and it would be nice to just get it out of the way sooner than later.
That's what im looking for, re-assurance before I go and spend $1700 on rims and tires. So, with the easy drop, 19x8 +30 wheels will work with NO fender rolling is what im gathering... And I was going to go with 235/35 series tires, unless there is a better option...
anx1300c
close
- Join DateFeb 2008
- Location633 Stag Trail Rd
iTrader Feedback Score(2)
Liked:933 Times in 615 Posts
Why roll if it's not necessary with current setup? Friend has machine, so I wouldn't do it unless you go more aggressive down the road.
The Machine
Registered Member
close
- Join DateDec 2011
- Age43
235/35 is a good option if you're looking for good road contact and no stretch. I had 235/35's on my old steup, but it was 19x8.5.
Ya, No stretch and I want as much rubber on the sidewall as possible but still looks good. Our roads here in upstate NY aren't the best. haha!
I pulled the trigger and ordered the wheels and tires just now. 19x8 +30 offset TSW Rivage in high gloss silver wrapped in Nitto 555 High performance tires 235/35 19. Mounted, balanced and hipped with all the necessary hardware, replacement tire certificates and $110 pre paid visa rebate card all for $1683.00 at Tires.com. Stoked!!
The Machine
Registered Member
close
- Join DateDec 2011
- Age43
Congrats.
I'm typically a fan of concave wheels in general especially in this style, but these should look pretty good.
Better get to painting your calipers, especially if they are rusted looking since they will be highly visible through these wheels.
Ya, Im a research whore, so I did lots of homework before deciding and buying. But ya, im stoked. Should def look good. Caliper painting is on the list ASAP, im thinking Red will look nice with the silver and the nighthawk black. But haven't decided yet. Ill be posting all kinds of pics once all is installed.
The Machine
Registered Member
close
- Join DateDec 2011
- Age43
If you have stock base brakes, I would suggest against doing a flashy color, especially red. The stock brakes aren't much to look at or draw attention to. The red will make them look kinda cheap looking, IMO.
My suggestion to dress the brakes up a bit is to paint them black, then add the RDX covers.
It's your car and can do what you want, just my opinion on the subject.
That sounds like it would be a good idea if the brakes are cheap looking. RDX covers? From the suv?
The Machine
Registered Member
close
- Join DateDec 2011
- Age43
Yes, they are from the 2013 Acura RDX suv.
Here is the part number 45218-TX4-A00
If you order from www.acuraoemparts.com and type ACURAZINE in the comments box when you order, you will get a discount. It won't show immediately as it is not a live system. An employee there has to check a database for orders and when they see ACURAZINE on the order form the discount is then applied. All 4 for me cost $50 shipped.
I had 19x8+30 wheels before with 235/35 tires and dropped with a 1 finger gap all around. Had natural camber in the front and a rear camber kit with -1.00 degrees around. Did not rub at all.
I wouldn't bother rolling your fenders at all.
Sweet! Sounds like I made a good decision with the wheel and tire package I went with. Should hopefully have them in the next two weeks on and rolling. Pics to follow. Thanks for all the help guys! Much Appreciated! Originally Posted by Vietnastee
I had 19x8+30 wheels before with 235/35 tires and dropped with a 1 finger gap all around. Had natural camber in the front and a rear camber kit with -1.00 degrees around. Did not rub at all. I wouldn't bother rolling your fenders at all.
Quote:
Originally Posted by bluetl04
im in for pics....
And they will be coming ASAP. Wheels and tires don't ship until the 15th, so I got a couple of weeks until they are on im sure. When I get them, what part of the forum is the spot to post build pics?
The Machine
Registered Member
close
- Join DateDec 2011
- Age43
You can always post a pic in this thread to show us how it turned out, but if you really want to show them off you will have to make a thread in the Photograph Gallery section.
https://acurazine.com/forums/3g-tl-photograph-gallery-96/
Cool. Will do as soon as wheels and tires get here and I get them on.
The Machine
Registered Member
close
- Join DateDec 2011
- Age43
I like them. Nice design and I like the contrast as well. Looks like there is still plenty of room, but I'll ask anyway.....Did you have to roll the fenders?
TheLowLife
close
- Join DateApr 2012
- LocationGreenville, SC
- Age40
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:705 Times in 538 Posts
Diggin' the new wheels. Judging by those pictures that may be a rim that could be pulled off in a 20" size...
anx1300c
close
- Join DateFeb 2008
Those look clean! Similar to an A4 wheel. Now you need some 35% on those windows.
Thanks everyone! Im stoked with how it turned out. Time to focus on some performance upgrades...
Quote:
Ya, they do kind of look like the A4 wheel, and I don't do tint anymore as its just a reason for the PoPo here in NY to pull ya over. No tint = More money in my pocket. lolOriginally Posted by anx1300c
Quote:
Thanks man, Im digging it. No rolling needed and no rubbing even over bumps. Although, I am wondering if I should invest in rear camber kit..?..Originally Posted by The Machine
Quote:
A 20 could def be done with these.Originally Posted by TheLowLife
Quote:
Thanks Man! Apprecite it. Originally Posted by bluetl04
They look great bro...job well done!!!
They look classy, I like it! And i'm sure if you get a camber kit you will need to rool the quarters at least a little.
That's what I was thinking but from what I've been reading, camber kit may not be needed with such a small drop. Looks like just the alignment alone should suffice.
Exactly. I always get the Ingalls kit on my TL's just because it makes toe a lot easier to adjust and why not fix the camber just to make sure your expensive tires dont wear? Its worth the 150.00 to save 400.00 worth of tires IMO.
Idk, I was reading the sticky "do I need a camber kit" by heeltoe and from what I've read there, kit isn't needed. Good point though and I would probably only need the rear done since the front is only negative about .90. Rear actually wasn't too bad, it was around -1.29 or so if I remember correctly.
Yeah its really up to you. Just make sure to at least get an alignment to correct the toe
All Around Klown
19x8 seems kinda skinny... I would try 19x8.5
I'm running 19x8.5 (35mm offset) with 245/35-19
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/finally-ordered-my-wheels-871739/
https://acurazine.com/forums/showthread.php?t=871739
Im happy with the way it came out and the rim width. Its good enough for me Originally Posted by EvilJoker
19x8 seems kinda skinny... I would try 19x8.5I'm running 19x8.5 (35mm offset) with 245/35-19
My first ricer
350
My first ricer
close
- Join DateAug 2012
- LocationWillow Grove, PA
iTrader Feedback Score(4)
Liked:257 Times in 212 Posts
Looks good, I'm always a fan of a clean 5 spoke wheel, which is why I'll probably never change the stock wheels on my TL. They kinda look like stock but bigger.
Quote:
I've always been the same way man. Nothing like a nice solid 5 spoke wheel. Not only do they always seem to look good, they are so easy to clean. lol. And I agree with you there, our cars have one of the best looking factory rims IMO, and I kind of wanted to keep a classy almost factory look but with some flare. Thanks for the props Originally Posted by 350
Started doing my wheel and tire research, came across yourthread.
Car looks perfect, same approach I plan to take by keepingit stock… but enhanced… enhance…enhance (super troopers)
Im looking at the TSW Willows, prob do same size and offsetyou did. Can you post a pic from front or back showing how flush they look tothe fender.
Thanks for the inspiration bro!
