19s & 20s
19s & 20s
ok...i've been searching = =
can someone please help me out?
i've seen in this thread that some people use 19 for their wheels and some uses 20...and some EVEN mix both together with 19 front&20 back...
so i'm asking...
is it 19 or the 20 that fits the 3G TL?><"
thank you guys so much
so i'm asking...
B A N N E D
well if you see threads with people using 19s and 20s on the 3G TL, then i would guess both 19s and 20s fit?
Personally I am running 20s with no problems.
(another questions: what is the size of the wheel that comes with OEM TL?)
no..not true...you can just bolt the 20s on and drive without problem as long as you have the right tire size.
Stock wheels are 17".
but what's the tire size?
1 Post
the reason why you should change the suspension is because your car will look like a 4x4 without you dropping it. Since your going with bigger wheels, the car will sit much higher than stock, and in my opinion, you should lower your car because it will look much better. But if you put on bigger wheels, you will have a higher possibility with rubbing if you pakc the car with ten peoples
rockyfeller
07-31-2007 09:56 PM
