19" wheel and 40 Tire ??
I would like to know as well. I am looking in to 19's but the 35 diameter on Philadelphia streets will not cut it. I will bend my rim everytime i drive. Can you get a 40 tire on 19's and still have a 1" drop with the Eibachs?
Originally Posted by BukvaMan
is it possible ? im trying to get a more comfortable ride
by how much would the speedometer be off ?
You can go to tirerack, find your stock tire and size, go to specs and it shows all the numbers. Then get the specs on the size tire you want to put on and compare.
Look here: http://www.miata.net/garage/tirecalc.html
Originally Posted by JD TL-S
THAT IS AWESOME But its an estimate. Or maybe when buying tires there estimated. Because I checked my tires and the size doesn't match the calculator. Anyway its a good estimater. What I can't understand is the sidewall size seams much bigger on the 19" rim on the calculater?
Here's a link that I hope helps you out some. I'm also interested in possibly going to a 40 series tires.
http://www.rims-n-tires.com/rt_specs...84F87458ED2E7F
Tires are a bit wider than they are in the real world, but it is still great help to visualize potential changes.
Wow that is a great link you have. It tells me everything I need to know assuming that the stock offset is +45 which I think it is
Excellent link. Thank you.
Heres the one I used. Even shows the difference in speedometer readings vs actual speed
http://www.discounttiredirect.com/di...dJQnjwWsNkYYZW
cammy5
09-05-2015 12:26 AM
nuldabz
09-03-2015 06:49 PM
