19" rim on 2008 TL
19" rim on 2008 TL
Looking to transition into a summer tire to give my all weather tires a break.
I was browsing on crCraigsli and found ones I wanted for my TL .
They measure as 245/45R19 . 19X8.5 front and 19X9 rear. Good price and tires are in great condition .
The owner had them previously on a Honda Element .
I'm not looking to lower the vehicle.
My main concern is twofold.
1. Will it fit? Comfortably with no rubbing when turning or a full vehicle.
2. Will it look goofy not being lowered .
Please and thanks in advance .
Latent car nut
Received 2,005 Likes
Latent car nut
Even if the offset is correct, there is a very good chance those tires will rub. Why? Those tires are 2.3" in diameter too large (which will also cause significant speedometer and odometer error); coupled with a wider than stock tread width and I strongly suspect you'll have an issue with rubbing. FWIW, for 19" wheels, your car would need 235/35 R19 (exact diameter of OEM tires) or 245/35 R19 (diameter is 0.3" larger which will only cause a minor variance in the odometer and speedometer) tires.
Latent car nut
Registered Bunny
Bolt pattern on a Honda Element is 5x114 so that's fine. Offset prob around 38 to 45mm.
This is 225/40/R18, 36mm offset, 9.75 in the back and 8.75 in the front on base suspension. You be the judge if you think it fits or doesn't.
Latent car nut
Hmmm, not fond of the skinny tire/stretched tire look.
Latent car nut
I think you're responding to the wrong person; personally I abhor running oversized wheels as they destroy the driving dynamics of the car. The fact is, the 3G TL was designed to run either 17" or 18" wheels, using larger wheels will result ride, handling, acceleration, and braking will be negatively impacted; using smaller (smaller won't fit on cars with the Brembo brakes) will result in a slight improvement in ride, acceleration, and braking, but a reduction in handling.
One way or another, you'll need different tires.
yup 40 series on a 19" will not work with the TL, need 35 series but keep in mind 35 series will be REALLY harsh on the ride quality... for comparison my stock 5 spoke is 235/45/17 and my Varrostoen's tire size is 235/40/18 and the 40 series on the 18s ride so much harsher than the 45s on my stocks.. i cant imagine what 35s would feel like.. you'd probably feel every pebble/stone on the road
It's not that bad. On my TL-S, it feels like the suspension reacts better with 18 or 19" wheels than with the 17. Sure you feel the road more each time you go up a size, but there's not such a dramatic difference as you're implying.
I had 19s on my car a couple years ago and it was tolerable, and the size to me is just perfect in terms of look on the car. I'll be buying new wheels soon and I'm still considering 19s or 18s.
1995hoo
12-13-2005 09:54 AM
