18x8.5 Aspec wheel color
Old 04-20-2015, 10:39 AM
jthiessens's Avatar
I'm currently looking at a set with some heavy curb rash and contemplating fixing them myself or having them done by a shop for $100 a wheel. Has anyone had any luck with matching the gunmetal color and if you have what brand and color did you use?
Old 04-20-2015, 11:25 AM
Received 8,754 Likes on 6,751 Posts
Read through here:
https://www.google.com/webhp?sourcei...or%20acurazine
I recall someone mentioning "anthracite"
Old 04-20-2015, 12:14 PM
jthiessens's Avatar
Read through here:
Anthracite was for the type s waffles I belive
Old 04-20-2015, 02:00 PM
CLtotheTL32's Avatar
Received 9,526 Likes on 6,181 Posts
Dupli-Color GM 435 Light Gray Metallic is a direct match. I used that as touch-up before I had my wheels powdercoated.
ggesq (05-07-2015)
Old 04-20-2015, 02:44 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I use this to touch up my wheels also ^^^^
Perfect match.
Now if they were to be refinished in GM 435, I don't know how well it will match the original colour.
Old 04-21-2015, 07:56 PM
jthiessens's Avatar
How many cans would you say it would take to do all 4 rims? 2 maybe?
Old 04-21-2015, 08:06 PM
About two should be okay.
jthiessens (04-22-2015)
Old 04-22-2015, 04:34 PM
jthiessens's Avatar
when you touched them up did you use the touch-up paint pen or a spray can? I am unable to find the gm 435 in a spray can as i am redoing the entire set of rims.
Old 05-07-2015, 08:59 PM
jthiessens's Avatar
So I have been working on these wheels and decided to go with a color more like the waffles. Here is a befor and after shot, I think they came out looking really nice. Just need another coat or two of clear then a wet sand and a polish. Not bad as I only paid $175 for the wheels.
Before
After
The following 3 users liked this post by jthiessens:
Bladehopper82 (06-14-2015), bluetl04 (05-11-2015), EvilVirus (05-08-2015)
Old 05-07-2015, 09:05 PM
ggesq's Avatar
Received 2,183 Likes on 1,211 Posts
Wow, came out great. Good job.
Old 05-08-2015, 08:45 AM
Very nice!
Old 05-08-2015, 10:01 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Before
After
Awesome job. You should entail the items needed for this project.
Old 05-08-2015, 11:12 AM
wao... not bad at all!
Old 05-08-2015, 11:53 AM
dookie320's Avatar
great job!
Old 05-08-2015, 12:47 PM
mrkingstonvi's Avatar
Before
After
They look great. I'm thinking to redo my waffles as well. So which paint did you actually use? The Dupli-Color GM 435 Light Gray Metallic? or the Anthracite?
Old 05-08-2015, 01:09 PM
Excellent job
Turned out like new!
Old 05-08-2015, 02:24 PM
ScoobyTL's Avatar
Nicely done! I am redoing a set as well. Probably gonna go with Solaris Silver Metallic (NSX wheel color)
Old 05-08-2015, 10:40 PM
jthiessens's Avatar
Used 80,220,2000 grit sandpaper and a sanding block
2 cans of dupli color primer filler
5 cans dupli color paint (color of your choice)
2 cans of dupli color wheel gloss clear coat
Body filler/bondo of choice
Is what I used
Tape off the inside of the rim that you do not want to get paint on.
80 and 220 to get All the curb rash and imperfections in wheels out, sanding it down to get it smooth but not enough to take the gouges out. 80 first on the major stuff then clean it up with the 220.
Then I used some filler to fill in all the imperfections on the rims and then sanded smooth with the 220. I took it back down to where I only had just the filler in the rash area as to leave as little filler on wheels as possible. Be sure to sand or scuff up the entire surface you are wanting to paint.
Clean off all the dust from sanding then be sure to clean with a wax and grease remover and apply the primer. After it has dried take your 2000 grit and wet sand it to get out all the imperfections be careful not to sand off your primer. I did about 3 coats befor I wet sanded.
Next is your color. Same process as primer, Wax and grease remover entire surface, paint ( I did a can a wheel just to make sure I had good coverage). I did not wet sand after this step.
Last step is clear coat. Wax and grease entire surface again, 3 coats of clear and then wet sand and buff wheels to make them smooth as glass and get the orange peal out.
The entire process has taken me about a month as I am just doing it at work during my lunch hour which leaves plenty of dry time for the painting which is key.
I will post final pics up after the final wet sand and buff as I just cleared them today and want to give them the weekend to dry.
EvilVirus (05-12-2015), manhatton (10-05-2015), mrkingstonvi (09-19-2015)
Old 05-14-2015, 06:17 AM
Slayer-33's Avatar
Oh my gawd. Beautiful work bro.
How much would this cost me per wheel if I attempted this?
jthiessens (05-14-2015)
Old 05-14-2015, 07:18 PM
jthiessens's Avatar
I was quoted any where from $100-$125 a wheel which is not bad but I think I had maybe $60 in supplies total. I had extra sandpaper and extra filler at work so that did not cost me anything.
The time I had in them maybe around 7-10 actual working hours on them.
Old 05-14-2015, 07:38 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
Holy jeez! That looks AMAZING.
Old 05-14-2015, 10:05 PM
rockvilleTL's Avatar
Awesome work on that!
Have a bit of curb rash on mine as well, might make a weekend project out of this.
Old 05-15-2015, 12:49 PM
mvp2765's Avatar
wow, that refinished wheel looks amazing...awesome work!
jthiessens (05-15-2015)
Old 05-15-2015, 08:46 PM
jthiessens's Avatar
Going to try and get tires and get them on the car tomorrow.
Will try and post a few after shots, but no tires on the rims I bet makes it 100 times easier
Old 05-16-2015, 03:38 PM
jthiessens's Avatar
New shoes!
The following 6 users liked this post by jthiessens:
ABP_04TL (05-19-2015), Bladehopper82 (06-14-2015), EvilVirus (09-01-2015), GhostTL09 (10-12-2015), manhatton (10-05-2015), Slpr04UA6 (08-28-2015) and 1 others liked this post. (Show less...)
Old 05-17-2015, 12:36 AM
Slayer-33's Avatar
Excellent work baby J
Old 05-18-2015, 06:09 PM
webosu11's Avatar
Those look great! First impressions on the Motivos? I almost went with those on my Aspecs but ended up going with the Yokohama Advan Sport instead.
Old 05-18-2015, 07:12 PM
Aww yeah
KBP with Gunmetal A-Specs is the ultimate combo IMO.
jthiessens (05-18-2015)
Old 05-18-2015, 08:29 PM
ggesq's Avatar
Looks great!
Old 05-18-2015, 09:33 PM
jthiessens's Avatar
I put about 30 miles on them this weekend and they feel really good but that's comparing them to some wore out kumho ecstas. They are quiet and have good grip
Old 05-19-2015, 09:28 AM
TL-GIXXER's Avatar
Very impressive work. Nice.....
jthiessens (08-28-2015)
Old 08-28-2015, 12:01 PM
BreezyTL's Avatar
Received 1,046 Likes on 777 Posts
I am working on a set right now myself. Can't wait to finish them. They are sitting in primer as we speak.
The following 2 users liked this post by BreezyTL:
EvilVirus (09-01-2015), Slpr04UA6 (08-28-2015)
Old 08-28-2015, 01:05 PM
TL-S
quanaman's Avatar
Awesome work!! 18x8.5 Aspecs are the ultimate stock wheel! I'm soo glad you didn't go and paint them black; they look awesome in gunmetal.
The following 2 users liked this post by quanaman:
bluetl04 (10-04-2015), Slpr04UA6 (08-28-2015)
Old 08-28-2015, 06:20 PM
JuicyJuice's Avatar
nice tl man. i like it a lot
Old 08-28-2015, 07:49 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Sweet baby Jesus that car is AMAZING.
Old 08-28-2015, 08:44 PM
jthiessens's Avatar
Looks like yours where in the same shape mind where. From the looks of it your doing a great job, take your time and they will come out great. I can't wait to see them finished
Old 08-28-2015, 08:47 PM
jthiessens's Avatar
Thank you very much, I take a lot of pride in it.
Old 10-03-2015, 04:38 PM
racerock's Avatar
Check back in one year from now.
Hate to suggest checking back in after one year. Reason is that I have painted wheels and cars a lot over the years. Used Duplicolor 3 times:
1. Used it on a set of BMW wheels. Three coats like you to get it laying right. The clear yellowed and checked after about a year.
2. Shot another set and only used 2 coats. Sold the car. Figured that the clear checked because of the extra heavy coat.
3. Third set were wheels just like yours. Used 2 coats clear. Turned out just like yours...
1 year later - they are checking.
These wheels are truly attracted to the curbs by the way - next set of tires will be wider to get some protection or have the curb guard...
My wife drives it most of the time. But I must say that all 4 drivers have hit curbs... Including ME.
Is what I used
booma1218
05-03-2016 07:39 AM
GhostTL09
09-19-2015 01:57 PM
vincenttheboy
09-13-2015 09:20 PM
Tommiepickles24
09-10-2015 12:30 PM
Quick Reply: 18x8.5 Aspec wheel color
