18x10 +12 xxr wheels?
Thinking of purchasing these wheels for my UA6, and was wondering if this
Fitment would fit with only rolling fenders?? If anyone can help me out thanks
a couple questions to ask - are you lowered? do you have BBK? if you are not lowered, and have no big brake kit you should be okay. I am sitting about 24" from ground to fender in front and 24.5" in rear on BC coils, I am running 18 x 10 +25 squared on 245/40 rubber. I have rolled and pulled the fenders front and rear, but i didn't even need to do any of the rolling/pulled on the rear, but did anyway in the event I want to drop more...
So you will sit about 13mm further out or about 1/2", which would give you more inner clearance for BBK - best thing would be to test fit (if you are able to).
Here's a shot for comparison - keep in mind your would wheels would sit out slightly further...
Just lowering spring not sure what kind
6 speed, aahh, i'm pretty sure you have the big brake kit that comes with the 6 speed TL - 04 - 06 6speeds, and the 07-08 Type S came with the upgraded big brakes in the front, a good tool to use is the New wheel/tire thread - https://acurazine.com/forums/tires-w...d-pics-577276/
I don't have the BBK, so I can't completely be sure they'll clear...check the pic - if they look like ones on the left, that's the BBK they probably won't have the Acura Logo on it
I tried looking through those new wheel/tire threads to see if anyone esle has ran the same wheem specs,didn't see any.
Inspire08
01-13-2016 09:41 PM
