Notices
18 x 9 + 25mm rims
Old 03-12-2019, 11:02 PM
New Member
18 x 9 + 25mm rims
This is her on 17x8.5 + 30mm
anybody think I will get wheel rub with these specs? Iím bout to toss some summer rims on my baby and wanna keep her strait
Mhallstrom7 is offline
Old 03-13-2019, 11:40 AM
Registered Member
losiglow's Avatar
I have no idea on the 18's. I usually check Tirerack when it comes to wheel fitment because they have the diameter, width and offset options on there. However, they don't have 18's with a 9" width OR +25 offset that fit the 3G TL - which would make me a bit nervous.
But 17's for the win! I'm not the only one who has aftermarket 17's!
Are they lightweight? I don't recognize the pattern but they look lighter than the heavy stockies.
losiglow is offline
Old 03-13-2019, 12:21 PM
Received 14,040 Likes on 10,433 Posts
i'm running 18x9.5 +22 which more aggressive than your proposed setup.
I run a 265mm wide tire, which I want to go wider with a 275mm tire.
the only reason why I had trouble is because I'm dropped, however, with a few variables to play with...it's a NON-ISSUE.
at stock height, wouldnt be a problem...
You can always roll the fender and if you scared go to church
justnspace is offline
Old 03-13-2019, 12:27 PM
Old 03-13-2019, 09:32 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,167 Likes on 790 Posts
That's a purdy car!
gatrhumpy is online now
justnspace (03-14-2019)
Old 03-14-2019, 04:50 AM
Thank you kindly, those pictures were taken in 2017 and pretty much still looks the same today. time flies.
I want to clean up the curb rashes on the wheels and powder coat them an anthracite instead of being white. then throw a 275mm tire on, the 265mm tire is still a tiny bit stretched
Old 03-14-2019, 07:15 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
That's a lot of surface area!
Dom!nO
05-11-2011 11:56 PM
lito
05-29-2009 10:26 PM
Byruns
06-20-2008 10:22 AM
ari1856
07-26-2006 03:06 AM
DrDre
Second Generation CL Discussion (2000-2003)
07-23-2003 02:17 AM
Quick Reply: 18 x 9 + 25mm rims
