18 x 9 + 25mm rims
https://cimg6.ibsrv.net/gimg/acurazi...d996ae140.jpeg This is her on 17x8.5 + 30mm anybody think I will get wheel rub with these specs? I’m bout to toss some summer rims on my baby and wanna keep her strait |
I have no idea on the 18's. I usually check Tirerack when it comes to wheel fitment because they have the diameter, width and offset options on there. However, they don't have 18's with a 9" width OR +25 offset that fit the 3G TL - which would make me a bit nervous.
But 17's for the win! :clap: I'm not the only one who has aftermarket 17's! :blush: Are they lightweight? I don't recognize the pattern but they look lighter than the heavy stockies. |
i'm running 18x9.5 +22 which more aggressive than your proposed setup.
I run a 265mm wide tire, which I want to go wider with a 275mm tire. the only reason why I had trouble is because I'm dropped, however, with a few variables to play with...it's a NON-ISSUE. at stock height, wouldnt be a problem... You can always roll the fender and if you scared go to church |
That's a purdy car!
Thank you kindly, those pictures were taken in 2017 and pretty much still looks the same today. time flies.
I want to clean up the curb rashes on the wheels and powder coat them an anthracite instead of being white. then throw a 275mm tire on, the 265mm tire is still a tiny bit stretched |
That's a lot of surface area! :naughty:
