08 TL Suspension
Old 01-12-2019, 08:16 PM
BigTL's Avatar
08 TL Suspension
I have an 08 TL with 120,000 miles. It's riding a little rough and I'd like to start replacing or upgrading the suspension to get a better ride. I saw a suspension kit on eBay. What about shocks and springs? Is the kit all I need to replace? I just replaced the tires last month so those are good. Thanks
Old 01-12-2019, 08:53 PM
mhtut83's Avatar
Are you OK with a bit more firmer ride? Or trying to stay similar to OEM setup? Coilovers are the way to go, IMHO. I picked up a set of Tein Street Basis Z for $423.80 shipped! Can't beat that price! Check out Race Consulting Agency online if you are interested.
Old 01-12-2019, 09:01 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Interesting, you own the softest 3G TL by a pretty wide margin and you feel it rides too rough? That being the case, an aftermarket suspension kit is unlikely to make it any better. Then there is the issue of the kit you provided a link for, that is for an old Acura CL, it will not fit your TL.
Old 01-12-2019, 09:26 PM
BigTL's Avatar
Good catch. I wasn't paying attention.
Old 01-12-2019, 09:28 PM
BigTL's Avatar
I bought the car new off the lot. The ride was smooth. I'd like to get back to something similar, if possible. I'll take a look at what you posted. Thanks.
Old 01-12-2019, 10:13 PM
Null and proud of it
Midnight Mystery's Avatar
Buy OEM and it'll be just like day 1.
Old 01-13-2019, 07:37 AM
BigTL's Avatar
What do I need to replace?
Old 01-13-2019, 08:16 AM
Latent car nut
horseshoez's Avatar
The first thing you need to do is figure out what is wrong with your suspension. At only 120,000 miles it should perform to spec, errr, unless one of your dampers is leaking or of some of your bushings are trashed.
Old 01-15-2019, 06:26 PM
BROlando's Avatar
Received 1,163 Likes on 874 Posts
Are your tires worn out? Is the car aligned?
Have you checked bushings?
Is anything loose?
At 120K, the shocks should be fine.
Anything you replace with aftermarket is going to be worse than OEM Acura replacements, and potentially unsafe.
I would not be tempted to buy a cheap "kit" on eBay, consisting of mystery parts.
Find out what's wrong. Fix just that with OEM parts.
Or roll the dice on high quality aftermarket replacement (if you can find such a thing).
Old 01-15-2019, 06:52 PM
Whatever is worn. Shocks/bushings/dampers, whatever appears worn or out of spec.
Old 01-19-2019, 03:45 PM
BigTL's Avatar
Shocks/struts may help. How can I tell if the bushings/dampers need to be replaced?
trustrsx
26
03-19-2007 05:11 PM
jmbnova
03-10-2006 09:32 PM
Black2.3CL
01-10-2006 12:54 AM
PeterUbers
04-20-2004 05:42 AM
ngcreese
09-02-2001 06:24 AM
Quick Reply: 08 TL Suspension
