08 TL Suspension
08 TL Suspension
I have an 08 TL with 120,000 miles. It's riding a little rough and I'd like to start replacing or upgrading the suspension to get a better ride. I saw a suspension kit on eBay. What about shocks and springs? Is the kit all I need to replace? I just replaced the tires last month so those are good. Thanks
Are you OK with a bit more firmer ride? Or trying to stay similar to OEM setup? Coilovers are the way to go, IMHO. I picked up a set of Tein Street Basis Z for $423.80 shipped! Can't beat that price! Check out Race Consulting Agency online if you are interested.
Latent car nut
Received 2,005 Likes
Interesting, you own the softest 3G TL by a pretty wide margin and you feel it rides too rough? That being the case, an aftermarket suspension kit is unlikely to make it any better. Then there is the issue of the kit you provided a link for, that is for an old Acura CL, it will not fit your TL.
I bought the car new off the lot. The ride was smooth. I'd like to get back to something similar, if possible. I'll take a look at what you posted. Thanks.
Latent car nut
Are your tires worn out? Is the car aligned?
Have you checked bushings?
Is anything loose?
At 120K, the shocks should be fine.
Anything you replace with aftermarket is going to be worse than OEM Acura replacements, and potentially unsafe.
I would not be tempted to buy a cheap "kit" on eBay, consisting of mystery parts.
Find out what's wrong. Fix just that with OEM parts.
Or roll the dice on high quality aftermarket replacement (if you can find such a thing).
Is anything loose?
trustrsx
26
03-19-2007 05:11 PM
jmbnova
03-10-2006 09:32 PM
PeterUbers
04-20-2004 05:42 AM
