Yellow Spots
allergic to wintertime
Yellow Spots
I just had some new wheels and tires installed and while checking out the new stuff the day after, I noticed in my wheelwells a whole bunch of little yellow spots. I am not insinuating that they had anything to do with the wheel/tire install, but quite a coincidence that this is the first time I have noticed them. They seemed confined to the body kit pieces (side and rear skirts) and only around the wheelwells so far. I tried washing them off (a lot) but they won't budge. They are very small and abundant in quantity. I don't have pictures...just wondering if anyone knows anything. My only thought is to try a clay bar, but it would be interesting to find out what they could be. I tried searching the forum but not sure how to effectively find the answer through that method. It is a 2006 White Diamond Pearl with the body kit installed by the dealer when I bought it. Thanks in advance for the help.
OK...I tried the clay bar, and it didn't even remotely remove these spots. Does anyone have any other ideas? Does this mean it's some type of a defect with the paint? Any thoughts would be appreciated. Thanks.
If the spots look like little dots of rust you have rail dust on your car. This happens whenever you are close to a train. The spots usually appear on the flat surfaces of cars like tailgates and hoods,but it is possible to get rail dust anywhere. My best suggestion would be to use the clay bar again, and if you have an orbital buffer use that on it with a medium polish. If this doesnt work it will probably have to be repainted.
just to clarify, are these inside the wheel wells or are they outside on the paint itself? Can you take a picture so we can see this exactly. Also run your fingernail over those spots, can you feel them raised or etched in?
I'm thinking that these are much more "yellow" than rust, but I'm not sure. I just can't believe the clay bar didn't even budge them. Thanks for the thought. I may have to use the buffer.
Originally Posted by Turbonut
Run over newly painted yellow lines on the highway?
ITSJESTER
17
12-06-2018 02:29 AM
Acura604
20
08-05-2017 12:55 AM
